Anyone have the manufacture and part numbers for idler and tensioner bearings? I'd like to try to find them before taking my car down if I can.
Thanks,
-Eric
Thanks,
-Eric
BCA or Nachi 6203ZZE IIRC but better double check... these are for the metal ASP pullies...
You will also need a bushing (from Stillen) for the idler bearing because the inner diameter is too large.
Thanks! The bearings are different then for the Stillen plastic idler?Originally Posted by Chunger
BCA or Nachi 6203ZZE IIRC but better double check... these are for the metal ASP pullies... You will also need a bushing (from Stillen) for the idler bearing because the inner diameter is too large.
Quote:
If the idler pulley is spinning "eccentrically" then that my cause the belt to not run smoothly leading to.... you know.... Originally Posted by jdmmax
uhhh oh i don't remember that .......
I bought some extra ones Frank, give me a call this weekend.
Quote:
Who are you addressing?Originally Posted by slimer
i may need an extra idler.....pm me.
ASP sells the idler pullies for like $70
the bushings are like $3 from Stillen...
