Greddy RS BOV Installed but its not working!
Old Apr 28, 2005 | 10:58 AM
JustMaxin96's Avatar
I got my greddy RS installed this AM but its not releasing air when I let off the throttle. What could possibly be causing this? My old Blitz did the same thing and I just assumed it was old and then bought the greddy. So my question is, where should I tee the recirc hose coming from the BOV?
Thanks guys!
Old Apr 28, 2005 | 11:28 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Check your vacuum line to the bov.
Old Apr 28, 2005 | 01:37 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
Hey if you decide to put that blitz back on ill take the rs off your hands.
Old Apr 28, 2005 | 02:17 PM
Kevlo911's Avatar
Kevlo for President
Maybe you have it set for too much boost
Old Apr 28, 2005 | 02:41 PM
thanks for the replies.
Seximagtr- I checked the vacuum line from the BOV and it does have vacuum. I have that line t-ed into the line coming from my FMU. Does this sound okay?
Maxinprogress-no Im not selling it, I just got my charge pipe welded with the greddy flange this morning so theres no going back now.
Kevlo-I'll play with the soft/ hard settings after work and see what happens.
Thanks again for everyones help.
Old Apr 28, 2005 | 07:15 PM
matty's Avatar
It should be releasing Air at idle...if its doing that, then there is no reason why it wont work after you come off boost...you would have a TON of compressor surge
-matt
Old May 2, 2005 | 07:17 AM
it was not venting any air at idle at all. I adjusted the screw on top until my friend snapped it off, Im so frusterated.
Old May 2, 2005 | 09:07 AM
matty's Avatar
He broke it, buy a new one
-matt
Old May 3, 2005 | 07:34 PM
turbomax97's Avatar
not necessarily - what do you mean by broke it?... if it's just the screw - buy a new one, retap if needed.
Old May 4, 2005 | 07:30 AM
yeah he broke the adjustment screw on top, it snapped off and part of the screw is still in the BOV. Do you think I can take it apart and tap out the old screw and re-tap a new one?
nismomaxgtr18
Forced Induction
20
Mar 5, 2016 08:04 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kenc15
Aug 5, 2015 08:29 AM
