Interesting Find Re: Race Gas Fuel Cell
Old May 5, 2005 | 10:16 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Found this:
http://www.ka-t.org/forums/viewtopic.php?t=1595
Interesting concept. More useful for turbo and strip applications though.
Old May 6, 2005 | 06:23 AM
burtreynolds's Avatar
Vishnu makes a kit for the Evo's like this. This way is probably way cheaper though.
Old May 6, 2005 | 11:29 AM
Broaner's Avatar
2060lbs and falling...
Seems so complex. Why not just tune the car to run on 93 or add a couple gallons of 100+ every tank or something?
Old May 6, 2005 | 11:37 AM
Bags's Avatar
VG Ridah's Biatch Hoe
nice find
Only issue I'd have is weight... but if you run the 93 down enough, it won't matter
Old May 6, 2005 | 01:21 PM
Jime's Avatar
Here is my setup.
Old May 7, 2005 | 05:33 PM
slimer's Avatar
nice setup Jim. Is the A/B line separated by a ball joint or what?
Old May 9, 2005 | 04:51 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Your setup works for a returnless setup, however if you "Open B..Close A" on a return setup, you'd be pumping race fuel to the stock tank and prematurely kill your stock fuel pump by having the stock system deadheaded with no FPR.
A FPR before A and a valve post fuel rail should work similar, right?
Originally Posted by Jime
Here is my setup.
Old May 9, 2005 | 05:11 PM
Jime's Avatar
That should work, I never really though too much about it when I used it on the 4th Gen because I just had it setup for nitrous on race gas only.
Never thought a returnless system would make some things easier. Its just a way to build a fuel system cheaper, certainly not better. I don't like the idea of the fuel sitting there allowing the engine to heat it up.
Old May 9, 2005 | 05:20 PM
IceY2K1's Avatar
Yeah, your FPR is on the pumps housing, so it just dumps fuel when A is closed. However, on the return setup, the safety bypass valve will be open and overheating the pump. Not sure how long that takes to kill a pump though.
Old May 10, 2005 | 03:49 AM
Jime's Avatar
Yup thats why I don't worry about it, it can bypass to its hearts content. Actually when the car is idling its almost %99.9 bypass anyway.
I have tried using straight 114 and setting up the a/f for it but it didn't really gain me anything N/A of course, but its nice to have the option.
What I was thinking though is just put 94 in the cell and pump out the stock tank at the track to save weight. However, I am a bracket racer and with 20 races coming this season I want to be consistent more than try and gain a 1/10 or two so its not really important.
Right now I am running in the 13.6 range with full interior and all I change when I go to the track is the 2 front wheels, 10 mins and I'm ready.
Here is a pic of the front line of IHRA mod class I am running in, (35 in the class) check out their dial on the windows. Mostly 10 and 11 sec v8 cars, super consistent and years of experience racing, however its a challenge. Most of these guys have r/t's in the teens so its not like racing against the imports.
Old May 10, 2005 | 10:33 AM
Broaner's Avatar
That is f'ing awesome Jime. You running in a class like that. LOL.
Old May 10, 2005 | 11:29 AM
Jime's Avatar
I'll let you know if I ever win an event, only got to second round on sunday. Payout is $600 for win $300 for second, $100 for semi's and $50 for 1/4 finals. The street cars this year is only trophies so I need a challenge.
Here is the point standing from one race so far. Only 1 point but its better than most of the others.
http://www.torontomotorsportspark.co...ntstanding.htm
Old May 10, 2005 | 11:44 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
funny pic, Wheres Waldo? ...its awesome that you are running with them though
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
305head
Aug 26, 2015 09:03 PM
Team STILLEN
Aug 10, 2015 04:29 PM
