highest fuel pressure to use with FMU?
Old Jun 2, 2005 | 08:50 AM
20006spd's Avatar
At what point do to run risk of damaging the injectors? Is 90-100psi fuel pressure too high to run safely?
Old Jun 2, 2005 | 10:35 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
thats getting a little high on the duty cycle, but people have been known to push fuel pressures that high out of stock injectors. you run the risk of becoming static.
Steve
Old Jun 2, 2005 | 10:41 AM
20006spd's Avatar
duty cycle
i didnt realize that fuel pressure plays a part in the duty cycle of the injector. i though they were seperate factors. Three ways to increase fuel , fuel pressure, size of injector, and injector plusewidth, am i on track?
thanks for the help.
Old Jun 2, 2005 | 12:15 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yes, you are correct 20006spd.
People have pushed those pressures, however it is definitely NOT recommended or safe. Although, our deka-II style injectors we have are rated up to 8bar ~ 116psi.
Get an eManage($270ish) and bigger injectors($500ish used) IMHO.
Old Jun 2, 2005 | 12:53 PM
chris'smax's Avatar
don't listen to this guy, i did and wasted over a grand on my fuel setup
20006spd, get bigger injectors and emanage. It allows sooooo much more tunning ability and ability change different settings that running an fmu cant provide
Old Jun 2, 2005 | 01:13 PM
IceY2K1's Avatar
You've learned well grasshoppa...hai~!
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
