do i need a jwt ecu to run a z32 maf or can i use a safc
Old Jun 24, 2005 | 05:40 AM
blinelaxd27's Avatar
hey if i get a safc2 can i run the jwt ecu and bigger injectors and pump.. or do i still need to get the jwt ecu for optimum performance....??
Old Jun 24, 2005 | 07:04 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Originally Posted by blinelaxd27
can i run the jwt ecu .. or do i still need to get the jwt?
huh? do you mean if you can run the oem ecu?
Old Jun 24, 2005 | 07:30 AM
yea i mean: i have a z32 maf waiting to be installed... but i don't have a jwt ecu yet, and i read somewhere that if you install the z32 with a stock ecu then the air mixture will be messed. So i was wondering if the safc2 will correct for the bigger maf.
Old Jun 24, 2005 | 08:20 AM
Stephen Max's Avatar
I did some testing using a Z32 maf with my oem ecu and adjusting using the SAFC. I logged runs using a wideband O2, so I had accurate afr data. I found that at high rpm and about 11 psi boost I had to add in about 25% to get the afr down to 12.5:1. The oem timing map is too far advanced for boosting above 10 psi, though, and I had pretty severe detonation after 6000 rpm. For low boost levels it might be okay.
With the JWT ecu I have never had detonation, boosting up to 14.5 psi.
Old Jun 24, 2005 | 08:59 AM
I30tMikeD's Avatar
Basically what Stephen Max said...
It can be done with just the S-AFC on lower boost, like 5-6 psi, but it will be hard to get a good tune out of it. The correction factors will be all over the place.
-ReLLiK-
Apr 29, 2016 06:25 PM
BkGreen97
Apr 2, 2016 05:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
