FMU Needed after JWT install
Old Jun 28, 2005 | 10:11 PM
matty's Avatar
Will I need to keep my Cartech FMU Installed after I finish installing my 370's JWT and Z32 MAF ??
I know I will ok with running stock fuel pressure with my 370's and afr will be ok with my JWT, but with my MEVI installed, will I run into any leaning out problems in the higher RPM range ??
Will the AFR be ok with ----> Wablro, AEM FRP, 370's, Z32 MAF and JWT-ECU (programmed for 370, MAF, 7200 fuel cut) ??
-matt
Old Jun 28, 2005 | 10:37 PM
wunfstmax's Avatar
If you dont ill buy if from you.
Old Jun 29, 2005 | 12:13 AM
I30tMikeD's Avatar
There should be no need for the FMU, if there is then Jim Wolf needs to fix it.
Old Jun 29, 2005 | 05:26 AM
Stephen Max's Avatar
It all depends on how much air you are moving through your engine. The 370 cc/min injectors max out at about 400-420 hp at the crank, or 340-360 whp. At that point you need to go with larger injectors or bump up the fuel pressure with a fmu.
Old Jun 29, 2005 | 09:24 AM
Prodeje79's Avatar
Since you are using the Walbro, your base FP will prolly be a little higher than stock.
Use the AEM FPR to lower it to stock FP.
JWT keeps the stock FP unless otherwise requested.
So as long as you're are below the HP amounts Stephen mentions, you will not need the FMU.
Old Jun 30, 2005 | 01:16 AM
matty's Avatar
Well the Cartech FMU is for sale
4,000 miles on the rebuild I did myself...
I can take pics if needed
-matt
Old Jun 30, 2005 | 08:41 AM
wunfstmax's Avatar
how much do you want for it, will it come with any silicone hoses?
Old Jul 5, 2005 | 12:28 PM
matty's Avatar
Silicone Hoses for what ??
$200 plus shipping for the Cartech FMU, Bleeder screw, and one way check valve.
-matt
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
3rdmaxse0
Aug 18, 2015 08:25 AM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
