Why did my base FP drop? MEVI related
Old Jul 7, 2005 | 09:36 AM
JustMaxin96's Avatar
Whats up guys,
I have a FP question for you all, hopefully someone can help. I recently had my vacuum canister for my MEVI crack due to the heat and cause a bad vac leak. So what I did was just remove the vac canister and run the vac lines from under the valve cover straight to the actuator on the MEVI. This is just a temporary fix until my new vac canister arrives. Anyway, after I did this I noticed my FP at idle now reads between 28-30 PSI, it used to be at a constant 34 PSI at idle. The weird thing is when I turn the key to acc the FP gauge still reads 34 but as soon as I start the car it drops to 28-30 PSI at idle. Does anyone have any clue as to why this happened?
My fuel setup is:
AEM FPR
Walbro 255
Vortech FMU 6:1 (I believe)
Any help is greatly appreciated.
Old Jul 7, 2005 | 02:12 PM
leaving work bump
Old Jul 7, 2005 | 11:31 PM
iansw's Avatar
You have a vacuum/boost gauge?
What's it say?
The FP is directly related to vacuum pressure via the FPR.
You may still have a cracked hose or vacuum leak somewhere.
Old Jul 8, 2005 | 05:53 AM
my vac at idle is -20-22 in hg. The thing thats weird is that when I had a bad vac leak and a horrible idle the FP was solid at 34PSI. Now that I seem to have fixed the leak the FP has dropped. Thanks for your help.
Old Jul 8, 2005 | 10:58 AM
iansw's Avatar
The more vacuum the less FP.
When you press on the gas in normal operation, the vacuum goes to nearly 0 (or higher into PSI if boosting). As it gets closer to 0, Fuel Pressure raises.
So now that I think about it - what you're seeing is the effect of having more vacuum.
Old Jul 8, 2005 | 11:32 AM
so Im seeing too much vacuum at idle? I didnt know too much was possible. What would cause high vacuum? Thanks Ian!
Old Jul 8, 2005 | 12:49 PM
iansw's Avatar
No, you're just seeing the right amount of vacuum at idle. (17-22Hg is spec).
I suspect that you're fine and your car just idles at a lower FP than most - not usually . a problem if it's just at idle. What FP are you seeing at redline?
Old Jul 8, 2005 | 01:05 PM
around 90 PSI at redline (stock injectors) its hard to watch that gauge and the road. So you think its okay? Maybe it will go back to 34 when I put my new vac tank in. Which tank are you using? Thanks again
Old Jul 8, 2005 | 02:02 PM
jcy98maxse's Avatar
Turbo is too much fun!
Anyone know to install an aftermarket FPR? I've heard you the new FPR replaces the stock FPR, how do I seal or replace where the stock FPR goes on the fuel rail?
Old Jul 8, 2005 | 02:13 PM
iansw's Avatar
I'm using a NAPA tank.
90 PSI at redline is about normal for your setup - I doubt that your boost pressure was affected since 1PSI still = 1PSI.
You're fine.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
jonreidhead
Jan 6, 2016 09:38 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima-junky
Oct 7, 2015 06:13 PM
