TURBO OR TWIN TURBO ?????? maxima 95
hi, iam new in the forum and iam from Montreal,Canada and my cars is a maxima 1995 SE and iam going to bought a turbo kits the kit include 3 turbos ˙˙td05h˙˙ and i would like to know if i could put my maxima Twin Turbo or should a put only one .... a bought a Vq30de block .. i will go do all a have to do to be sur that de motor will accept change ... sorry for my english
JE SUIS QUÉBÉCOIS DE SOUCHE
hahaha
hahaha
to add onto the wonderful information that everyone else has supplied, i believe that there is not enough room to afford a pair of snails, and people have been able to get more than enough power out of one for the FWD to handle well. just go single. but why did you buy 3 in the first place?
Originally Posted by Batxel
whatd you get a buy 2 get 1 free deal???
, but that little "TWIN TURBO" sticker you get to put under the MAXIMA emblem afterwards would make it all priceless
.-Dexter
You use twin-turbos when you want to use smaller, less laggy turbos for better response, or when you want do do a sequential setup -- a smaller turbo that spools quickly for low RPMs, and a large turbo that delivers huge power at high RPMs.
Incidentally, Mercedes is using a tri-turbo setup on their new SLK320 diesel.... two itty bitty turbos off to the sides of the engine, and one big honkin' one in the middle of the cylinder banks.
But yeah... given how our engines are mounted (i.e. exhaust manifold front-and-back instead of left-and-right), it'd be MUCH more trouble than it'd be worth to try to make a twin-turbo setup. Might as well use only one -- pick the smallest, quickest-spooling one -- and craft everything else as well as you can to make as much power with that. The kids making ~300hp with NA 3.5 swaps already have crazy traction problems with 225-section summer tires; making anywhere near that with a turbo will make traction even worse, so you couldn't even really use the power. Might as well try to make the power delivery as smooth as possible.
MAXSE5SPD
Aug 23, 2015 12:06 PM
Team STILLEN
Aug 10, 2015 04:29 PM
