Two quick set up questions
Old Jul 31, 2005 | 07:21 AM
I30tMikeD's Avatar
With no vacuum source to the FMU it will not raise fuel pressure correct? Fuel will just flow through the FMU with no change? Don't want to remove the FMU just yet till I know the JWT ECU, injectors, and MAF all work...
With a JWT ECU programed for a Z32 MAF and using a Z32 MAF what is the correct setting on the SAFC-II. Z32 in and Z32 out correct? Which is 4 in 4 out?
Trying to get this sucker done! Thanks!
Old Jul 31, 2005 | 08:27 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you're right. no vacuum source=no pressure=1:1 rising rate.
do you want me to bring out my discs?
Old Jul 31, 2005 | 09:09 AM
I30tMikeD's Avatar
No need, didn't spend $600 on an ECU to use an FMU. Just want to bypass till I know the new stuff works.
550's are in, now the MAF.
Old Jul 31, 2005 | 09:51 AM
slimer's Avatar
if i bring my stuff out later, could we do it?
I really want to see how you wire up the MAF.
Old Jul 31, 2005 | 10:07 AM
matty's Avatar
I really hope you have better results than I did...
-matt
fulloboost
Sep 12, 2015 08:03 AM
Jcof88
Sep 9, 2015 03:11 PM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
