Dyno numbers
Old Aug 25, 2005 | 05:25 PM
maxmaxima91's Avatar
Dyno numbers
Max WHP 271.38 @ 5600
Max WTQ 276.81 @ 4500
Stock VG block and Heads with 173500 miles on it. 11 psi running Rich as hell, 10.0-10.5/1 afr. I know I know its rich but im waiting to get a bigger MAF to borrow my buddys wideband. Also i have the timing set at about 22-23 degrees in boost. Im guessing that if i leaned it out i could get almost 300 WHP on the same boost.
Ill post the Graph up as soon as i can scan it.
Jeremy
Old Aug 25, 2005 | 05:39 PM
Kevlo911's Avatar
Kevlo for President
Not bad, what do you use to tune?
Old Aug 25, 2005 | 07:08 PM
Nealoc187's Avatar
SLOW
Nice job Jeremy.
Old Aug 25, 2005 | 07:16 PM
JClaw's Avatar
Boosted 3rd gens are cool VG seems pretty damn tough.
Old Aug 25, 2005 | 08:12 PM
you bet... im aiming for around 400-450 to the wheels eventually on this same moter. if not more... tranny will be the weak link.
Thanks neal.
Im useing Live edit with a romulator on my stock ecu. ive wideband tuned it but i left it way to rich because i was scared. management works great... 30 mpg highway, 20 around town, 1 while boosting
Old Aug 25, 2005 | 09:27 PM
subs1000w's Avatar
nice get er near 12:1 and she'll sceam
Old Sep 12, 2005 | 04:01 PM
alright.. i finnaly got my dyno slip scanned.. here it is. since then i have tested my boost gauge and found that it is accually about 1.5 psi high so i was accually running about 10 psi when i did this dyno.
Old Sep 12, 2005 | 04:03 PM
how do you make the picture show.... grrrr
Old Sep 12, 2005 | 04:14 PM
Nealoc187's Avatar
SLOW
Curve looks good. Can you raise the rev limiter with live edit? If your valvetrain and rod bolts, oil pump, etc, can take it, you should do it. You are still making good power up top.
I'm going to put your dyno curve in Cartest and see what it says for optimal shift points. I'll post back up when I have the results.
I don't think you can make those yahoo photos show because the the contain a valid image extension.
I saved it and hosted it for you.
Old Sep 12, 2005 | 04:20 PM
Thanks neal, and thanks for hosting it to. i can raise the rev limiter but i dont know what i can rev this old 2 valve up to. bottom end can pobably handle 6500 no problem but im worried about the top end.
Old Sep 12, 2005 | 04:28 PM
Nealoc187's Avatar
SLOW
Does a 91 SE have the same gearing as a 92+ SE with the VE engine? I will look that up next I guess. Assuming it does, cartest is tellin me that you should shift at redline in 1st gear, however high you are willing to take it (6500, 7000, even 7500), then shift from 2nd to 3rd at 6700rpm, shift from 3rd to 4th at 6400, 4th to 5th at 6100. Remember this is using a 92+ SE gearing, I'm going to go try to find out if the 91 gearing is the same right now.
Old Sep 12, 2005 | 04:29 PM
im really think it does... but i do not know for sure. i want to look into it and find out what people are reving stock VGs to. i would shift higher if its safe... i pulls like hell even at 6k rpms. Thanks for plugin it in.
Old Sep 12, 2005 | 04:30 PM
Nealoc187's Avatar
SLOW
Just found out that the 91 SE has the same gear ratios, but a taller differential. 3.65 diff vs 3.82 diff for a 92+ SE. I put this in and it doesn't change the shift points more than 10-20rpm, so still the shift points I listed above are best.
Old Sep 12, 2005 | 04:38 PM
k... now it makes sense. my buddys VG maxima was faster than mine when we were both N/A in the top of the quarter mile. he has a 92 tranny swap.
Old Sep 12, 2005 | 04:44 PM
Nealoc187's Avatar
SLOW
I just tested the hypothetical 1/4 mile times with the different rev limiters, assuming a badass launch and the shift points I posted above.
With a 2.10 60' time on each, it's giving me this for 1/4 mile times:
6000rpm limiter: 13.47 @ 106
6500rpm limiter: 13.32 @ 107
6700rpm limiter: 13.30 @ 107
7000rpm limiter: 13.30 @ 107
So as you can see going from 6000 to 6500 would get you a good gain, around .15 seconds in the 1/4, but going any higher than that doesn't really do anyting for you. .02 seconds isn't really even worth mentioning since your runs will probably vary more than that each time you run from things just like wind, your shifting, etc. But a full .15 seconds is a great gain, if you feel it's safe for the motor.
Old Sep 12, 2005 | 04:49 PM
Nealoc187's Avatar
SLOW
Yeah it's showing about .1 second improvement for a stock VG using a 3.82 diff from a 92+ maxima rather than the 3.65 in the 1991's.
Old Sep 12, 2005 | 05:25 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
nice numbers jeremy.
Old Sep 12, 2005 | 05:41 PM
wow... you can do alot with that program, thats so cool. Im going to see if its safe to rev VGs to 6500....i think it might be. Also, yea he was always running about 1-1.5 tenths of a second faster than me in the quarter, he was always pulling away in the top of 3rd gear.
Old Sep 12, 2005 | 07:27 PM
Brad92SE's Avatar
Decent numbers, congrats! Lean that thing out now and see what she'll do!
Edit: By the way, if you start cranking up the boost, watch your tranny. I damaged mine when my boost spiked (wastegate came disconnected) and it eventually blew up. Not to discourage you, but if your gears aren't any stronger than the VE ones don't be surprised.
Old Sep 12, 2005 | 08:16 PM
subs1000w's Avatar
its safe to rev a vg 6500
Old Sep 13, 2005 | 10:01 AM
Ya, the VG trannys arent any stronger than VE trannys. The only thing ill have going for me is the fact that i have a HUGE turbo. Therefore the power always comes on smooth and never hits hard. and i dont have an extremely tight clutch so in between shifts isnt to bad.. Still im worried about my 3rd and 4th gear.
Old Sep 13, 2005 | 02:05 PM
Boosted Maxima's Avatar
The VG tranny is stronger than the VE? Realy? no wonder your having trouble Brad
Brad has been rebuilding trannys in his sleep for the last 3months!
I just thought it's been luck that's saved mine.
~Scott
Old Sep 13, 2005 | 02:28 PM
Brad92SE's Avatar
Well, my problem was that I overboosted just accelerating, I did shift, but not hard. The tranny blew up when I was just accelerating in 1st, no shifting involved. Shattered the small input shaft gear (the one thats molded into the shaft) and chipped my first main gear.
~Scott
He said they arent any stronger. Sorry Scott, you are running on luck.
i never said they were stonger.... if anything ive only heard that VE trannys are stronger, nothing for sure though
Old Sep 13, 2005 | 02:37 PM
subs1000w's Avatar
the VE and VG trans are identicle except for the lsd
Old Sep 13, 2005 | 11:43 PM
Maxpwer's Avatar
No turbo, no care!
Actualy, the VE trans has larger bearings and larger axles.
Old Sep 14, 2005 | 09:07 AM
Nealoc187's Avatar
SLOW
Sounds like you guys that keep breaking transmissions need to get one modified so you don't have to rebuild your transmission every weekend.
Old Sep 14, 2005 | 09:12 AM
i havent broken mine yet... im still original for the car, 175000 yeah buddy
Old Sep 14, 2005 | 10:04 AM
subs1000w's Avatar
it only has larger bearings on the differential aka vlsd but nobody ever has problems with those
Old Sep 14, 2005 | 12:03 PM
Brad92SE's Avatar
Thats going to be my next project. No more power till my gears are stronger.
Old Sep 14, 2005 | 12:12 PM
is third gen turbo guys have to figure out a good way to beef up our trannys... with the power that i would like to be pushing someday im definatly going to need it. That or i am going to change to a different tranny, with adapter plates and custom axles (if needed) the options are endless. Although im thinkin about the new 6 speed given that is tougher. dunno just a bunch of ideas.
Old Sep 20, 2005 | 10:14 PM
95turbo gxe's Avatar
when I dynoed I held my max horse power till 6000rpms! That was before I ported the heads or added cams.
Old Sep 20, 2005 | 11:06 PM
cool, you should post a graph so we can compare them. never know what we could learn.
Old Sep 21, 2005 | 06:02 AM
Brad92SE's Avatar
Indeed. This spring I will be tackling this issue. As of now, I was thinking a cryo treatment and shot-peen would help quite a bit, along with a full rebuild. It shouldnt be too expensive with the gears already out of the case.
Old Sep 21, 2005 | 02:44 PM
Nealoc187's Avatar
SLOW
Don't bother doing anything to the trans unless you get the gears detailed, that's my opinion. That is the best thing you can do to the trans to make the gears stronger.
Old Sep 21, 2005 | 03:28 PM
Brad92SE's Avatar
Neal, what do you mean by detailed?
Old Sep 21, 2005 | 03:53 PM
Nealoc187's Avatar
SLOW
Check out the thread I posted a few weeks back describing in detail all I had done to my transmission it's all in there. It's probably a few pages back.
jmlee44
Oct 2, 2022 02:13 PM
maxinout93
Oct 31, 2015 02:04 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
