410cc injectors+Z32 Maf+A32 Ecu+4:1 FMU Disc= A Little Rich
Old Sep 1, 2005 | 09:43 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
So it was in the upper 60's lower 70's last night and I hadn't been able to drive the max for a while because some elementary issues cam up. I had to make two 20 mile trips on the highway, so I decided to tune. I used the manumatic to lock myself into second to do a primary base tune. I was hitting 8.5 psi on the zt-2 display with my 3.33" pulley.
Without and SAFC corrections, I was seeing 10.2-10.5 AFR from 3400-5400 rpms and then it went up to around 11.0 at redline. It seems to me that the 4:1 FMU disc gives you plenty of fuel to boost safely. It is a little rich, but if you do not have access to a dyno, it will keep you a little on the rich side.
I made corrections of -5% from 3400-5800 and then put it to -1% by redline. The AFR's were a little better, but most of them were still in the 10's.
After a couple of more runs in both 2nd and 3rd gear, the measurements came out like this:
2800rpm -5%
3400rpm -13%
4000rpm -14%
4400rpm -13%
4800rpm -11%
5200rpm -10%
5600rpm -5%
6000rpm -4%
6600rpm -2%
I didn't want to go over -10% correction in fear of messing with timing, but I guess that -14% is okay.
This gave me an AFR of anwhere from 11.4-11.8 in both 2nd and 3rd gear.
Another thing that I noticed is that unlike 5 speeds where they have to let off throttle when they shift gears, I was able to maintain a 12.0 AFR while the gears shifted. I though that it was interesting.
If anyone else has a similar setup, please let me know their configurations as well. I should be dropping pulley sizes soon (c'mon matty) and will want to tune with the SAFC-II while the quirks of the EMU are being worked out.
Steve
Old Sep 1, 2005 | 10:41 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
I wouldn't worry about pulling too much fuel, especially around your torque peak.
I would worry about ADDing a bunch of fuel around your torque peak.
Old Sep 1, 2005 | 10:42 AM
IceY2K1's Avatar
BTW, you got a webpage yet?
slimer's Avatar
I was just happy to see that the 4:1 disc made everything pretty even across the board.
Old Sep 1, 2005 | 10:43 AM
slimer's Avatar
uh, let me work on it. I may have one by the end of the week. I just need to talk with one of my business associates.
Old Sep 1, 2005 | 10:53 AM
IceY2K1's Avatar
WTF...just upload some pictures over at cardomain.com man.
Old Sep 1, 2005 | 02:47 PM
slimer's Avatar
i have old ones. hehe, haven't really taken the time to update it.
Old Sep 1, 2005 | 02:52 PM
IceY2K1's Avatar
Well AT LEAST edit your sig to include your latest mods, ie a simple breakdown of what you got.
I can't keep track of all of you FI ****** mods.
Old Sep 1, 2005 | 02:54 PM
slimer's Avatar
Yes Sir!!!
Old Sep 1, 2005 | 03:08 PM
IceY2K1's Avatar
Old Sep 1, 2005 | 07:59 PM
I30tMikeD's Avatar
So what was the solution to the problems you were having a few weeks back?
Old Sep 1, 2005 | 08:06 PM
slimer's Avatar
its my ignition switch. i got a "new" one that crapped out on me on the way to the bears game tonite. If I don't get one from the dealer tomorrow morning, I will probably not be able to make it out tomorrow nite.
Old Sep 1, 2005 | 08:07 PM
slimer's Avatar
oh wait, with the injectors? oh, an o-ring was pinched and some harness was loose. everything is working fine with the injectors. for deatchwerks!
Old Sep 12, 2005 | 06:21 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
hey what do you have your throttle opening setting set at? Lo#% high#% ?
i think mine are off
Old Sep 12, 2005 | 07:57 PM
slimer's Avatar
I have the HI set at 40%.
Old Sep 13, 2005 | 11:47 AM
pawnstar12's Avatar
and whats your low?
Old Sep 13, 2005 | 08:48 PM
slimer's Avatar
I haven't set the low. The ecu seems to learn it.
msellas
Sep 23, 2015 09:16 PM
ballerchris510
Sep 10, 2015 09:35 PM
AT978
Sep 6, 2015 10:31 PM
