help with emanage setup
Old Sep 19, 2005 | 08:10 PM
mad-max98's Avatar
i'm running a32 ecu and z32 maf ,550 injectors and emange i have injector harness and usb cable,, anything else i need to get for tunning???
Old Sep 19, 2005 | 10:09 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
ignition harness(not necessity, but useful!)
and just remember to set the injector value differences from 370cc as the original and of course 550cc as the new value. one mistake a few guys(myself included) made is to use the stock Maxima value with the Z MAF instead of the Z32's 370cc as the original injector value.
Old Sep 19, 2005 | 11:40 PM
mad-max98's Avatar
what can i do with the ignition harness
Old Sep 20, 2005 | 12:17 AM
Nealoc187's Avatar
SLOW
Retard ignition timing...
Maybe map sensor and harness to if you want to tune by MAP.
Old Sep 20, 2005 | 01:54 AM
mad-max98's Avatar
neal what's better?? you guys been there so i'll take your advice and findings
Old Sep 20, 2005 | 05:43 AM
DA-MAX's Avatar
how much power do you plan to make?? you don't really need to pull timing until 10-11psi so you technically wouldn't need the ignition harness until then, but why not pick one up I say. the MAP sensor isn't bad to have either, but with you using the Z MAF/550s its not necessary right now either since you won't really exceed the Z MAF very soon and need to tune by MAP.
Old Sep 20, 2005 | 04:57 PM
mad-max98's Avatar
i plan on running 15 psi hopefully ,not right away because i need to get familiar with tuning the max first oh and i just bought venom 555 for 220 bucks hoooooooooo
Old Sep 20, 2005 | 05:18 PM
DA-MAX's Avatar
15lbs?? have you done any upgrades to your transmission?? you will need the ignition harness as well because you will have to pull timing after 11psi
and Venom injectors don't have the best reputation at all in the import world, I'd watch them VERY closely. I would have spent the extra money and gone with the injectors Mike's brother makes...we ran a set of his 590s in Redmax's car with no issues.
Old Sep 20, 2005 | 10:10 PM
mad-max98's Avatar
i have a 5spd and planing on getting the 6 puck clutchnet but i still have time to get to that point however how much timing do you pull after 11 psi and for the injectors they're to be used for a short period of time till i find a set of nismos,, how can you watch the injectors ??afr guage or something else!!! thnx hommies
Old Sep 20, 2005 | 10:16 PM
DA-MAX's Avatar
Nismos are fine but expensive, go with these..like I said we used a set of his 590s on a turbo max with no issues-->
http://forums.maxima.org/showthread.php?t=343641
IMO there is no definite amount of timing to pull, but its been discussed before look back through a few of the emanage threads in the forum
you can buy any clutch you want, but the stock 5spd tranny internals won't last past 14psi(from what i have seen and experienced)....3rd gear will be the first to go.
Old Sep 21, 2005 | 12:32 AM
mad-max98's Avatar
i gotta look for that thread about timing but i have a lsd from 2001 if that makes any difference , i have to buy raxles also ,do you think i have to get both sides or just the driver's,,, i'm not really planing on running past 15 psi but i'm planning on using nitrous up top when my efficiency starts to fall off <i have that turbo http://forums.maxima.org/showthread.php?t=423912>
Old Sep 21, 2005 | 01:16 AM
Nealoc187's Avatar
SLOW
Be careful of 3rd gear if you really run that much power though it. You only need the driver's side axle. Get deatschwerks injectors forget the nismos unless you like paying extra for the same thing.
Old Sep 21, 2005 | 04:06 AM
choray911's Avatar
The Crazy Azz Cracka
The timing harness has two functions. One is to retard timing to keep the car from detonating when cylinder pressures and temps get too high. That keeps you from buring holes in the piston tops, and burning a valve. Generally this retardation isn't needed until you get up in the 11 psi rating that was mentioned before.
Secondly is the potential for additional power. There are only two ways to make power, Cylinder pressure, and ignition timing. The turbo takes care of the cylinder pressure and the timing harness allows you to let the piston go down a little more before the spark fires. When my car was on the dyno I was able to gain 40hp at 6psi just by backing some timing out between 3500, and 6500rpms. We had the afr set using the maf adjustment, and the additional injection harness, all of a sudden we backed out some timing and she opened up.
The ignition harness isnt required, but the Emanage has potential that you are not using. Its just a few dollars more go ahead and pick one up. Just make sure you get the updated software before it is installed, other wise you could melt the coil packs.
Choray
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
