Still running :D :D :D
Old Sep 28, 2005 | 08:34 AM
sleepermaxima's Avatar
Contrary to popular belief (myself included), the max is still running!
Why am I surprised? well some of you might remember a while back when I sc'd the max without getting any sort of modifications done to the factory ECU. I said I planned on running juice with that setup. Well...
This setup is jetted to give about a 75 shot.
I have emptied my first bottle and I'm thinking I need a bigger shot I do not hear a hint of knock and that damn motor still pulls like hell.
Recap on my setup...
I have:
V2 SC with 3.1 pully
Blitz BOV
z32 MAF (mounted on charged side)
370cc injectors
Walbro 255lph HP fuel pump
AEM Adj FPR
N.O.S. Pro Fogger system
Running Sunoco 104 R/M Unleaded fuel
I'm not using or don't have:
Water/Alch Injection
SAFC2
FMU
Aftermarket ECU
I'm not saying that this is a dependable setup. I'm only saying that it can be done and it can run pretty strong too. This motor was burning a quart in 500 miles before I ever sc'd it (but oil consumption has not changed since then though).
The AFR is about mid 11's while spraying. Pretty rich but that is where I like it.
Track day is the 8th of October. If the weather holds out and I am able to run, I will post my times to give you an idea of the pull this motor is generating.
Again, as always, thanks to the guys that helped make this possible.
D
Old Sep 28, 2005 | 10:11 AM
matty's Avatar
A quart every 500 miles !!!!....thats worse than my moms 2.0 VW jetta...eeekkkk
Good job on the car though...you have a WB hooked up I pressume since your seeing a/f
-matt
Old Sep 28, 2005 | 11:12 AM
Stephen Max's Avatar
Looks awesome. I'd love to see a dyno. Running the 104 octane fuel is saving your butt, I bet.
Old Sep 28, 2005 | 11:59 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
That direct port looks nice. How much work was involved with that?
Old Sep 28, 2005 | 12:40 PM
Thanks. Check out my homepage... I have more pics (before/after) on the first page. That should give you an idea of what went on.
Since i took my time with the install, I think I prolly spent about 30 hours or so on the actual install. Things like making the solenoid brackets, running the SUPER SHORT 6an line from trunk to the engine bay, bending those mother f'ing hardlines, installing the button in the steering wheel and cleaning up my old installations.
Also, since this was a 4cyl kit (hence the super short line) I had to track down a ton of odds and ends which also took a while since I was a newb to this particular setup.
It was a lot of work but the end result has made it worthwhile.
Old Sep 28, 2005 | 01:07 PM
ewuzh's Avatar
I hope he's not running synthetic!!
Old Sep 28, 2005 | 01:25 PM
Hell no kinda funny since it doesn't leak and it doesn't smoke
It's not a big deal since I have only been putting on about 100-200 miles a month on the car this summer... and it's getting cold over here again so it will soon be relegated to the garage for a few months.
Old Sep 29, 2005 | 07:24 AM
Boosted Maxima's Avatar
I put a 50 shot kit on a Supra one time that was already converted over to single 66mm turbo front mount ect ect. 50hp sure felt like alot more when the boost came on. let us know how it go's with reliabilty and power.
~Scott
Old Sep 29, 2005 | 07:33 AM
I30tMikeD's Avatar
What fuel pressure are you running at 0 vacuum? Turning up the fuel pressure can easily make those 370's flow more like 400-420 cc's.
I agree with Stephen, it is the 104 octane that is saving you from detonation. Although I bet your still getting a little bit but enough that your knock sensor can handle it.
You ever see you AFR's under WOT w/o spray?
Job well done. I bet that thing pulls really nice with the spray!
Old Sep 29, 2005 | 02:46 PM
Requin6's Avatar
did you have enough hood clearance for that DP setup?...it looks to stand a bit high.
hood scoop?
Old Sep 29, 2005 | 06:58 PM
Nealoc187's Avatar
SLOW
How much boost is the 3.1 pulley?
Thank god for 104 or you'd probably be having some knock probs. Nice setup on the nitrous too
Old Oct 7, 2005 | 03:48 PM
It's set to stock pressure so something like 44psi at 0 in hg.
yup...The 104 is a must. I can run about 98 without the juice on a cool day but even then it will detonate after a good heat soak (like while sitting in traffic and then nailing it once the road opens up).
The AFR is in the high 10's to low 11's without spray under WOT. Kinda sucks but it works.
Old Oct 7, 2005 | 03:52 PM
hood scoop?
Nope. It all fits. But I was VERY worried right up until I closed the hood after bending the first line. Good thing the engine bay was made to fit those MEVI's. The lines fit right in that little hole in the hood insulation.
No rubbing/rattling either.
Old Oct 7, 2005 | 04:01 PM
I get about 10psi with that pulley (6700 redline).
no doubt. $5 a gallon but very worth it.
thank you
1/4 mile races are tomorrow... I can't wait to try it all out... almost done with the wireless "naaaawz" button install too.
Old Oct 9, 2005 | 09:48 PM
95turbo gxe's Avatar
looks nice rock it while it last
Old Oct 9, 2005 | 10:12 PM
Nealoc187's Avatar
SLOW
It blew up he said in another thread.
Old Oct 10, 2005 | 05:21 AM
BigLou93SE's Avatar
Yea, I saw that and was looking for an update here...I'm sure hell be in sometime.
Old Oct 10, 2005 | 06:26 PM
yup. it's out of commission. I have not been able to tell what failed. I know I messed it up good. From what I can tell, each bank has one dead cylinder. So I think I can blame it on two things, lack of safe guards on the nitrous sytem and irresponsible spraying.
Old Oct 10, 2005 | 07:43 PM
slimer's Avatar
So are you going to get another engine?
Old Oct 10, 2005 | 07:57 PM
absolutely.
Old Oct 11, 2005 | 02:09 PM
Broaner's Avatar
2060lbs and falling...
Its all on the 104. Chit works wonders. Get J&S and run more boost/juice.
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
