Car cranks but wont start
Old Oct 24, 2005 | 01:47 PM
wunfstmax's Avatar
It cranks and cranks but no start. I know the fuel pump is pumping, I hear it when I turn the ignition to on. Im also seeing 18 psi from my fuel pressure gauge with it in the on position. My battery is charge so I don't think that its the problem. I installed my spark plugs a few months ago, and they ran fine. Im lost, any help would be appreciated.
Old Oct 24, 2005 | 02:33 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
18 psi is very low. what fuel pump are you using?
Old Oct 24, 2005 | 02:48 PM
wunfstmax's Avatar
walbro 255lph gss342
Old Oct 24, 2005 | 03:06 PM
wunfstmax's Avatar
Ok, I adjusted the fuel pressure its up to 46 or so with the key on on position.
Old Oct 24, 2005 | 03:13 PM
Requin6's Avatar
did it start?
Old Oct 24, 2005 | 03:18 PM
wunfstmax's Avatar
oh sorry no it didn't start. It really sounds like its going to then just doesnt
Old Oct 24, 2005 | 11:15 PM
jcy98maxse's Avatar
Turbo is too much fun!
what injectors? do you have spark? is the cylinders flooded?
Old Oct 25, 2005 | 06:35 AM
wunfstmax's Avatar
Right now the injectors are stock. I checked one plug and it was dry.
Old Oct 25, 2005 | 06:49 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
any CELs?? after you check the coils for spark, check all the other usal suspects...crank snesor, coolant temp sensor, head temp sensor(not sure if related to a no start)
Old Oct 25, 2005 | 12:34 PM
wunfstmax's Avatar
yeah its the crankshaft position sensor. Any one that may have a one for sale???
Old Oct 25, 2005 | 12:38 PM
slimer's Avatar
jiggle it a little and check the wiring connection. you may not have to replace it.
Old Oct 27, 2005 | 11:34 AM
TJ_Max's Avatar
Paradox Systems Vendor
hey, also check the "start sig" fuse and the rest of ure fuses in the fuse box in cabin....it took me 3 cranks and a hold to get my car to start, i noticed my start sig fuse was blown.....same exact symptoms as u...give it a shot...maybe that will do it...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
Balkins
Aug 12, 2015 06:39 AM
