why do injectors wait to leak
Old Oct 27, 2005 | 08:28 PM
95turbo gxe's Avatar
ok well got my car back running ok for now intill dyno. Since the motor rebuild,adding, cams ,370cc injectors, and fpr. Ok well I drove it up and down my road for a while and did not get to far off from home. well every thing went fine. So i get enough ***** to ride accross town to where all my friends was. ok shut the car off and went to crank it back up to leave and boom it was skipping realy bad. SO i check the fuel pressure and show enough it drops on the gauge fast. But I wonder why dont they leak at first and why it a takes a while for them to do so. I went through this when I put my 259cc injectors in a while back.
Old Oct 27, 2005 | 11:08 PM
maxmaxima91's Avatar
dunno man but i sure does suck... ive had it happen to me and my buddy a few times... Stupid Side feed injectors... i would recomend once there fixed before you put the manifold back on preasurise the Fuel system and if they dont leak Wiggle all of them inthe fuel rail while under pressure, just to make sure the lower Injector seals are seated correctly. thats basically the only way ive found to try and be sure there right before you put it all back togeather.
Good luck.
Jeremy
Old Oct 29, 2005 | 03:35 PM
ok got it injectors three was porring. So its back to running ok(driveable)
Old Oct 30, 2005 | 06:52 PM
ok well I thought I had it fixed and boom I drove it around town, got it running a little smoother. Like after about an hour after driving it, their goes it again another injector leaking
Old Oct 30, 2005 | 09:05 PM
man you got worse luck than me.... you might want to get all brand new nissan OEM seals for the injectors if you already havent. ive found that some of the aftermarket ones suck and are to small
Jeremy
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
REDinLV
Sep 28, 2015 12:31 AM
