370cc injector question
Old Nov 15, 2005 | 10:32 AM
gassian's Avatar
I am planning to turbo my car...
since my injectors are leakin and not holdin pressure after dealer ran tests on them.
I am planning to get 300zx turbo 370cc injectors.
As far as i know it should fit in 4th gen maxima.
Is this going to be a good with stock FPR and stock ecu with upgraded fuel pump?? and am i goin to run rich??
and if someone can tell me the part # for the injetor would be great
thanks
Old Nov 15, 2005 | 04:22 PM
gassian's Avatar
anyone???
i really need to get this done asap...coz i know mingo is almost done with the piping.
Old Nov 15, 2005 | 04:55 PM
ewuzh's Avatar
You need an afpr to lower your base fuel pressure down or you'll be idling really rich (if you manage to idle at all).
larger injectors = more fuel volume per pulse
upgraded fuel pump such as a high pressure walbro 255 = increase idle fp from 34psi to ~42psi.
Old Nov 15, 2005 | 05:07 PM
gassian's Avatar
oh okay...is the N/A 300z injector 370cc also?? or its like our stock injectors?
thanks ewuzh
Old Nov 15, 2005 | 05:26 PM
jcy98maxse's Avatar
Turbo is too much fun!
NA 3z injectors flows like our stocks. only turbo 3z flows 370cc
Old Nov 15, 2005 | 05:56 PM
95turbo gxe's Avatar
what a great reason to go boost ! way to go
Old Nov 15, 2005 | 07:49 PM
JAY25's Avatar
370CC and a Z32 MAF. That is all you will need. Dont need to even mess with your FP!
Old Nov 15, 2005 | 10:13 PM
gassian's Avatar
sounds good...i'll do the MAF and injectors and hope everythin goes well
thanks Jay25
Old Nov 15, 2005 | 10:37 PM
chilled's Avatar
I suppose the z32 maf compensates the duty cycle automatically?
Old Nov 16, 2005 | 06:45 AM
JAY25's Avatar
Someone is using that setup right now NA. He was boosted just had not had a chance to pull off the injectors. Z32 bigger MAF will compensate. Its a larger MAF. I used the setup too. Going right to it.
Old Nov 16, 2005 | 07:07 AM
naplesmaxima aka Tommyali the scammer!'s Avatar
I scam therefore I am
say you are N/A and you add a 300ZX MAF what will that do for you and is it a direct bolt on?
Old Nov 16, 2005 | 08:31 AM
JAY25's Avatar
no no you dont want to do that. Unless you are boosted. Dont do that unless your planning on putting on a SCer or turbo in the near future. I am sure he just wants to bolt that on now so thats one less thing that has to be done. The guy who has this setup is pulling it off so he can get rid of the stuff. The Z32 is a bolt on, how ever you have to tap into the stock harness to make it work. Not hard at all. Just go to the JWT site and it will tell you how to make it work. ONly three wires, power, ground and signal wire. Thats all.
Old Nov 16, 2005 | 11:07 AM
oh ok thank you
Old Nov 16, 2005 | 09:19 PM
gassian's Avatar
i got a check engine today....got three codes..
1) Improper shifting to first gear
2) Idle speed control
3) Ignition signal circuit
the reason i am askin this in this forum coz i know all the boosted guys are really knowledgable about this car..
i posted this on the 4th gen forum but didn't get enough response
and here is the described issue that i have in cold starts
http://forums.maxima.org/showthread.php?t=439575
Old Nov 17, 2005 | 07:18 PM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
i got sr20det 370's for sale http://forums.maxima.org/showthread.php?t=440643
Maxboy23
55
May 1, 2025 06:09 PM
jmlee44
Oct 2, 2022 02:13 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
