Pic of reclocked blower and 3" piping.
Hey guys I'm pretty new to F/I and I've been readin as much of the posts about The Stillen S/C's every chance I get and I've never heard the term "reclocking."
Forgive me for being slightly off-topic but, would anyone mind explaining this term/process and what's its purpose/advantage is? Thank you.
Originally Posted by Stephen Max
No, just up to the maf.
1 question: In rerouting the piping to the front of the car, would there be any major advantage to cutting in an intercooler?
awsome dude thank you.
Post 73 shows dyno results before and after installing the intercooler. The before dyno is with the intake routed around the front, like what I did with SlamdMax. Bottom line is, I didn't lose any peak power, but I did lose area under the curve. In order to take advantage of the cooler intake air, I need to be able to advance the ignition timing.
Here is the thread describing routing the intake around the front of the car.
http://forums.maxima.org/showthread.php?t=328904
Originally Posted by ptatohed
You only had 4? I had 5 allen screws when clocking. 4 holding two of the straps and 1 holding a broken strap "piece".
Same here, I had 5. Iansw, the 5th single allen screw is underneath the blower. You can still clock it with just 4 of the 5 screws loose. If you felt underneath the blower you will feel that single screw. I reclocked the blower this weekend also. It was pretty easy.
Originally Posted by SPiG
What was that close?
Originally Posted by iansw
I bet you're getting some wicked compressor surge with your HKS SSQ there....
I miss my HKS SSQ - too bad it never leaks under vacuum ever....
OT, but is that an Odyssey PC680? If so, let me know how that works out, if you don't mind.
Oops. The huge, thick 3" 90^ elbow coming off the blower.
Finally got the car up and running. Time to check out this whole compressor surge business..
Yes, that's the PC680. Specifically, it's the PC680MJT. MJ=metal jacket T=Terminals
For those who are curious...the metal jacket is recommended, but not mandatory for automotive use. The metal jacket is to prevent engine heat and vibrations from affecting the performance of the battery. The gold terminals are necessary to convert the female connection of the battery to a male connection. (See link)
http://www.batteryweb.com/odyssey-de...Model=PC680MJT
I've had the battery for about 3 months, no complaints so far. The car has sat for two weeks (with the alarm off) and it started right over. Gotta love it! Only 15 lbs!!
Originally Posted by slimer
James, I love how that AWAC fits in there sooo nicely.
Thanks Steve, but the AWAC isn't in yet. What you see is a temporary 3" aluminum pipe (cut to the exact length of the AWAC). I just paid for the AWAC last Friday and it shipped Monday. I have done some preliminary stuff like getting the Vortech ice chest to fit etc etc. After I ordered the AWAC, I left off with the guy to contact me or Josh if another one comes in. It will be all yours if you want it! BTW, did you ever measure the temperature drop with your AWAC?
:o)
I haven't. The reason why is 1. I don't have a dual temp gauge like I want and 2. Its way to cold to do any work on the car. Since we're in the rental house, the garage seems to have no insulation at all. Even in long undies working is uncomfortable. It would be nice to see how the sub freezing temps changed the iat though.
Can you post a pic. of you in your long undies?
You don't want to see that. Trust me!
Josh/James
are there any plastic parts in the JR kit? I'm wondering because if I replaced my AWAC with it, I may want it powdercoated like it is now.
Josh/James
Originally Posted by VQ30DENX_SC
Was that fat elbow from "intaketubing.com" or whatever site?
Please tell me u arent getting compressor surge at idle. i want the ssqv so bad.
Josh/James
James, have you had any problems like Josh did with the coupler blowing off?
q
my god, that looks like 5 inch charge piping, lol. Was that fat elbow from "intaketubing.com" or whatever site? Please tell me u arent getting compressor surge at idle. i want the ssqv so bad.
For years I thought that "flutter" at low RPM was he BOV.
Turns out that was in fact compressor surge. You might want to pop your hood and rev the engine and listen - if it is what I think it is you will quickly see what I mean. Put your head near your blower and listen.
I hope this gets resolved soon Wizard, ive got my mouse pointer on the "check out now" button for that BOV, lol. i wish there was some way to modify it.
Originally Posted by chris'smax
gotta question, are you guys using aluminum pipe or SS. Which one is better for heat resistance?
:o)
I way prefer aluminum. But Jim and I had a hard time finding aluminum elbows. We only found aluminum straight pipe. If you hold up one of each, you'd be very amazed how light aluminum is.
Originally Posted by ewuzh
Why do you want it so bad?
Because i'm tired of hearing all these sleek high tech flutters and chirps and "clinks" when i roll out with my turbo friends....with my obvious ghey a$$ "wooosh!". Getting sick of it really. They are really stealthy sounding.
I had to go to a Vortech Mondo bov to get rid of compressor surge. Largest bov in the free world.
Does the Mondo Vent air at idle ?? How tight do you keep the mondo. ?? Looks like i may need to upgrade to a mondo.
-matt
haha
