**Matty's SuperCharger Parts List**
Old Nov 19, 2006 | 12:01 PM
  #41
MyownNismo's Avatar
Future Camaro SS owner
is this the FMU needed.
http://www.superchargersonline.com/p...ber=V6Z110-143
Old Nov 19, 2006 | 12:43 PM
  #42
matty's Avatar
Originally Posted by MyownNismo
I would recommend this unit http://www.superchargersonline.com/p...umber=BEG-2027
Just because when you go to upgrading things, you can full adjust this unit with a set screw on top. With the Vortech unit you need to upgrade disks and it becomes a pain.
Both are good though. The Vortech Units are found on Ebay alot for $50-$60
-matt
Old Nov 19, 2006 | 01:50 PM
  #43
MyownNismo's Avatar
-matt
yeah but will it be harder for a SC newbie like me. I allready decided to recirculate the BOV. the SC plate is out being powdercoated. going to stick with a V2 S-trim instead of trying to go T-trim. As soon as I got the plate a got a renewed spirit. Just hope I can make the auto last through it with some helping parts.
Old May 11, 2007 | 11:41 AM
  #44
VIP Maxima
for the charge pipe, wouldnt it be easier to just have an exhaust shop bend a 3" pipe for you and cut an opening for the BOV??? i am guessing the hardest part would be the last bend to attach to the blower.
it might look ugly at first but thats not a problem, a plish and coat would make it look nice.
Old May 11, 2007 | 12:06 PM
  #45
ewuzh's Avatar
Most exhaust shops pressure bend their pipes. You'll lose a lot of internal piping diameter going that route. For the BOV, you need to weld on a flange, not just cut a hole in the pipe...
Old Jul 5, 2007 | 11:03 AM
  #46
VIP Maxima
Originally Posted by i30ds
Is this the exact oil feed line I need?
http://www.stealthmodeperformance.com/oil-feed.shtml
It looks like it is a bit too short (not quite 4 feet).
did anyone try this item? its -3an and not -4an. i understand both would do. but aside from being short, are both ends the correct measurement to fit the blower and T adapter? can anyone confirm this item from experience?
Old Jul 5, 2007 | 06:04 PM
  #47
i30ds's Avatar
Armed and Dangerous
Waaaay to short... by about a foot. Buy their block fitting and then just pick up the rest outta a Summit catalog.
Old Jul 5, 2007 | 06:36 PM
  #48
i30ds's Avatar
Armed and Dangerous
Since I keep getting a lot of Q's about the oil feed line:
http://forums.maxima.org/showpost.ph...64&postcount=6
Old Sep 2, 2007 | 06:04 AM
  #49
iLLin-2k1's Avatar
Dumb Question... But I was searching in ebay for "Vortech" and I looked in the price range you suggested and didn't find a V1 or V2? Is that price for used or new? As going to their website the price of a supercharger is 2200 or so.
Am I a confused noob or what?
Old Sep 2, 2007 | 08:29 AM
  #50
matty's Avatar
You can find "Used" head units on ebay from anywhere from $500-$1000.
"NEW" your lookin at $2200-$2600
-matt
Old Jun 11, 2008 | 01:47 PM
  #51
STRICTTLYNISMO's Avatar
I HAVE SOME QUESTIONS CAUSE I BOUGHT MINE SUPERCHARGED
im not reading no boost only vaccum which. the boost line is t twice. 1 line goes to the manifold, 1 line goes to fpr, 1 line goes tobov, 1 line goes to boost gauge, etc. if this is incorect. how can i route this properly
Old Jun 11, 2008 | 01:49 PM
  #52
also,what the max amount of boost u can use on a stock motor and how do u tell what pulley u have. all i know is that its 6 rib
Old Jun 11, 2008 | 04:56 PM
  #53
matty's Avatar
Its always a good idea to find a seperate source of Vaccum for the Boost gauge. I have everything T'd at one place for everything BUT the boost gauge. I have the boost gauge coming off a seperate vac source past the manifold.
Old Jun 11, 2008 | 05:50 PM
  #54
The size of the pulley is usually written in small white font on itself, assuming it's a genuine Vortech pulley.
As for the max amount of boost, there are too many variables to give a definitive answer.
Old Jun 11, 2008 | 07:39 PM
  #55
OK WELL THE MAX I WOULD WANT TO RUN IS ABOUT 10LBS. WHAT IS THE PART NUMBER FOR THAT PULLEY, CAUSE WHEN I LOOK ON VORTECH WEBSITE. THEY DONT GIVE A SPECIFIC BOOST AMOUNT
ALSO NOT SURE IF ITS A DUMB QUESTION, BUT THE VORTECH WEBSITE WQS CONFUSING ME.
WHEN U GO UP IN DIAMETER BOOST PSI GOES UP ...OR
WHEN U GO DOWN IN DIAMETER BOOST PSI GOES UP ??????
Old Jun 11, 2008 | 07:41 PM
  #56
6-Rib Supercharger Pulley (2.62") $78.95/ea
2A036-287 6-Rib Supercharger Pulley (2.87") $78.95/ea
2A036-312 6-Rib Supercharger Pulley (3.125") $78.95/ea
2A036-325 6-Rib Supercharger Pulley (3.25") $76.95/ea
2A036-333 6-Rib Supercharger Pulley (3.33") $78.95/ea
2A036-340 6-Rib Supercharger Pulley (3.40") $76.95/ea
2A036-348 6-Rib Supercharger Pulley (3.48") $78.95/ea
2A036-361 6-Rib Supercharger Pulley (3.60") $78.95/ea
2A036-380 6-Rib Supercharger Pulley (3.80") $78.95/ea
2A036-450 6-Rib Supercharger Pulley (4.50") $78.95/ea
2A036-500 6-Rib Supercharger Pulley (5.00") $78.95
Old Jun 11, 2008 | 07:58 PM
  #57
i read on here some one on here has the 3.33 pulley and is running at about 10 lbs. whats size pulley are you running matty and how much boost do u get if u dont mind sharing?????
Old Jun 11, 2008 | 08:28 PM
  #58
Please don't ***** up Matty's thread with off topic questions.
Check out the stickies here in this forum. The answers you seek are there.....
See here.
http://forums.maxima.org/showpost.ph...34&postcount=8
As you go down in pulley size, boost goes up.
Old Aug 30, 2008 | 11:59 AM
  #59
rdoug26's Avatar
Does anyone have more info on where to purchase a radiator overflow bracket?? I'd rather find one than fab one.
Old Aug 31, 2008 | 10:52 AM
  #60
rdoug26's Avatar
Originally Posted by slimer
I got one from Misuno(sp?) And I put it next to my brake bleeder. It was like $20.
http://cgi.ebay.com/ebaymotors/Moros...spagenameZWD1V
does anyone know how much tubing and what kind to use with the above catch can? or where to find the 5/16" thin wall... Ive tried the generic auto parts stores
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
