Wideband O2 sensor time
Old Mar 16, 2006 | 01:25 PM
Turbo95Max's Avatar
Turtle turtle... Moderator
Ok...so ive been looking up Wideband kits recently and its juss making me more confused
Im looking for a wideband O2 with a gauge and datalogging ability. I looked at a few Innovative ones. LC-1, LM-1, XD-16. I dont care too much about the meter that comes with the LM-1. what do you think of the PLX M-250?
what would you guys recommend for what i want? thanks
Old Mar 16, 2006 | 03:43 PM
Jime's Avatar
Gauge is really not necessary. Datalogging is a must. Mine has both and gauge is hardly ever used, just something pretty to look at. Monitoring is useless, datalogging for tuning is priceless.
Old Mar 16, 2006 | 04:14 PM
virgilio7's Avatar
i think a gauge is very usefull cause in case something is wrong you can see if the a/f changed for some reason.
datalogging is the real tunning solution but gauge is good for monitoring just in case.
Old Mar 16, 2006 | 07:25 PM
Turbo95Max's Avatar
i wanted to have a gauge so i can see whats going on when i drive. maybe its not totally necessary but more for peace of mind.
which wideband are you using?
Old Mar 18, 2006 | 12:36 AM
Spanners's Avatar
LM-1 all the way.
I use one daily.. briallint.. don't even bother with a Motec of Microtech unit.. waste of money.
Old Mar 18, 2006 | 04:19 AM
Jime's Avatar
This is what we call a false sense of security. The gauge will not save you. By the time you see the air fuel is out, you have already melted two pistons. Remember at even 6000rpm you have 100 revolutions per second which is in and around 20-30 combustion sequences. If it takes you one second to see the air fuel is out and let off you have already gone through so many combustion sequences that your screwed. It's proven you simply can't lift fast enough to save the motor.
Again, an air fuel gauge is totally useless even a wideband one. It's sometimes nice to look at going down the track to re-affirm that everything is ok, but really it's only a light show inside the car. Even from a tuning standpoint you can't watch it and make changes, it's just too fast.
Old Mar 18, 2006 | 08:55 AM
vsamoylov
so you guys say a LM-1 is a good buy? also a question do most of the wideband o2 provide a second output that will feed the stock ecu so only one o2 sensor has to be used?
Old Mar 18, 2006 | 09:45 AM
Nealoc187's Avatar
SLOW
Unless they've increased it, the LM-1 has only like 88 seconds of datalogging on the unit itself which to me isn't very much. That and the huge size of the unit are the turnoffs for me. Oh and the fact that I had the power cable socket completely fall off the circuit board the first day I used it. Luckily I was over at MikeD's house and his uncle is a very experienced solderer because he worked at an electronics/microchip company, so he did some very fine soldering work and got the thing fixed for me.
Old Mar 18, 2006 | 11:09 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Try ~44 minutes.
Old Mar 18, 2006 | 11:26 AM
Nealoc187's Avatar
SLOW
Hmm wonder where I am remembering that figure from then. Maybe from another wideband.
Old Mar 18, 2006 | 03:34 PM
MaximaEvolution's Avatar
what do u guys think about the Zeitronix Zt-2?
Old Mar 21, 2006 | 01:01 PM
Y2KevSE's Avatar
Here's an example of a log of the LM-1 with RPM converter. Without the RPM converter, you'll only get AFR vs. time. The RPM converter lets you add up to 6 more things to log.
Old Mar 21, 2006 | 11:53 PM
John at J&S's Avatar
Jime:
Sales of widebands to J&S units is running about 1000:1.
I need to hire you as a PR guy.
Old Mar 22, 2006 | 08:50 AM
maxgtr2000's Avatar
KH3 by popular demand
I have the Zeitronix but if I had to do it again I would get the top of the line PLX. I think its the m-500 or something. I little pricey but nice.
Old Mar 22, 2006 | 07:20 PM
what advantage would this "m-500" have over, say, the LM-1?
Old Mar 23, 2006 | 11:22 AM
Jime's Avatar
Originally Posted by John at J&S
Jime:
Hmmm I was hoping for a 1/2 price deal.
Old Mar 23, 2006 | 11:42 AM
steven88's Avatar
Need A Light?
So is buying a WB o2 sorta like personal brand preference? I mean most decent units I see on ebay have datalogging capabilities...so why do some cost more than the other? Accuracy?
I'm in the market for a nice decent one....no LCD/gauges for me, cuz I don't wanna light show and want to save the $100-$150....anybody have any reccomendations?
also how hard is installing a WB? I already got a spare o2 bung in my test pipe...i just put the WB in there, route the wiring through the firewall, then plug everything up and call it a day? or is there more stuff involved? thanks!
Old Mar 23, 2006 | 04:24 PM
vq356sp's Avatar
El Mas Noob Del Org.
same question as steven88?
Old Mar 26, 2006 | 11:48 PM
steven88's Avatar
Need A Light?
BUmpity bump...
I'm most likely going for the Zeitronix ZT-2...a local is selling it for like $250 brand new without the LCD....not too shabby of a price for a WB with datalogging capabilities....Are all of you ZT-2 owners have a ball with this WB? I want to make sure I'm making the right decision before I go out and buy it...
I'm only tuning with the V-AFCII and sticking with bolt ons...and I only need datalogging capabilities for AFR to RPM...no PSI, EGT, LAMBDA or whatever...just plain old AFR to RPM....is the ZT-2 good enough for this task?
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
yat70458
Aug 3, 2015 01:16 PM
