Spark plug problem
Old Apr 12, 2006 | 12:44 PM
wunfstmax's Avatar
Spark plug problem
Well I looked at the other thread but its not the same symptoms that I'm having. I was getting a code for multiple cylinder misfire. I was still running stock ngk, and thought that going to the bkr6e-11 would help. Well I'm not getting the misfiring code anymore but now there is a lot of hesitation. They are gapped to .040. Any help would be appreciated.
Lorenzo
Old Apr 12, 2006 | 01:08 PM
C MAX's Avatar
mine are gapped to 0.38 so that shouldnt be the problem, might be an injector or bad coil
Old Apr 12, 2006 | 01:35 PM
wunfstmax's Avatar
Well the hesitation wasn't there before the plug change now it is.
Old Apr 12, 2006 | 02:54 PM
C MAX's Avatar
you might have messed up a coil, make sure they are all plugged in tight. it sounds like some sort of spark issue.
Old Apr 12, 2006 | 03:06 PM
wunfstmax's Avatar
Ehh, I went ahead and pulled a plug its lightly coated with white residue. Im going to put the others back in for now. Could this have anything to do with elevation(Im at 6000+ ft)?
Old Apr 12, 2006 | 03:18 PM
Nealoc187's Avatar
SLOW
I don't know how much boost you are running but it might be that your plugs are gapped too large. If I tried to gap my plugs to .040" my car wouldn't go anywhere if I went WOT, mine are gapped at like .032".
Old Apr 12, 2006 | 04:48 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
well as mike knows that when i first did my plugs i gapped them to .036 and they car was bogging and not moving under boost at all, i gapped them to .040 and they worked like a charm, weird i know, si I think .040 should be fine for you.
Old Apr 13, 2006 | 11:26 AM
wunfstmax's Avatar
Well the I found out what the problem was....they were to loose. Runs great now.
Old Apr 13, 2006 | 09:58 PM
Nealoc187's Avatar
SLOW
too loose as in they weren't screwed in tightly?
Old Apr 13, 2006 | 10:53 PM
wunfstmax's Avatar
yeah I guess i rushed it or just wasnt paying attention.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
knight_yyz
Nov 6, 2015 02:34 PM
chernandez1278
Sep 16, 2015 01:18 PM
