FI with TS ECU too much timing?
Old Apr 20, 2006 | 05:52 PM
TOdouble's Avatar
i was wondering if anyone knew if the timing was too agressive on the TS ECU to run it with a FI setup.
thanks in advance!
Old Apr 20, 2006 | 08:45 PM
Nealoc187's Avatar
SLOW
The TS ecu for NA maximas? Yes, wayyyyy too much timing advance.
Old Apr 20, 2006 | 09:09 PM
I30tMikeD's Avatar
Not a good idea at all.
Old Apr 29, 2006 | 05:45 PM
crewchief264's Avatar
yes it will be way to advanced my stock ecu was giving it 43degrees at points. however t/s can reflash your ecu
Old May 3, 2006 | 04:31 PM
ptatohed's Avatar
Licensed to Spell
Don't use it. You might be able to safely advance your timing with an inter/aftercooler but probably not as much as the G-Force ECU.
cruce91
Sep 20, 2015 10:23 AM
intimidator
Sep 5, 2015 07:23 PM
Slamrod
Sep 3, 2015 07:38 PM
t6378tp
Aug 24, 2015 07:03 AM
