anyone using msd on their maxima?
Old Apr 23, 2006 | 07:52 PM
espimax's Avatar
have anyone put a msd on their maxima? if so which one are you using? any benefits with it what kind are you using is it the digital 6, how do you install it?
Old Apr 23, 2006 | 09:29 PM
John at J&S's Avatar
At least two problems.
MSD connects to coil neg and coil pos. Coil neg is inaccessible on Nissan coils.
MSD makes spark on rising edge of the trigger. Nissan coils spark on falling edge of the ECU ignition signal.
Old Apr 23, 2006 | 10:34 PM
espimax's Avatar
so, no good? for nissan ndi system?
Old Apr 24, 2006 | 07:07 PM
mtcookson's Avatar
I have a 6AL for my VG. I've hooked it up but never installed it due to not having the "tach adapter", which is supposed to make them work in a no fire situation which is caused basically due to a voltage drop from the signal being used on multiple sources or something to that affect... (sorry, I know that probably sounded very confusing so read below to clear it up)
Basically, the MSD 6AL made an immense difference in the power of the spark when spinning the distributor by hand. I'm sure it'll have no problems making a big difference on the low end.
You do need the tach adapter to make it work though. I have everything needed but haven't actually ran it yet... yes, I'm that lazy. Had it for 3 years and haven't installed it.
Not sure what setup you'd need for the coil pack setup though. I would think that setup (individual coil packs) would be more than enough though. The VG uses the good ol' dizzy setup so has some room for upgrade (not that its terribly bad or anything though.)
Old Apr 24, 2006 | 07:42 PM
Chris Gregg's Avatar
Get Off My Lawn
Curious: are you talking about VE engines? Even the coils on the Ve have a +/- , so how is neg unaccessable?
On the VG, Both are accessable. I used to run a Jacob's ICE Pack. I went through two of their "ecu's" before dumping the system. I subsequently went to using only the upgraded coil, which is plugged into old coil wiring +/- signal.
Old Apr 24, 2006 | 08:10 PM
jeremykedel's Avatar
I have seen msd on one maxima,A turbo one built by central florida turbo had a 3.5 in it with a full microtech ems.
Old May 3, 2006 | 03:09 AM
mjk's Avatar
mjk
Head shot!!!
http://www.my350z.com/forum/showthread.php?t=184800
is this anything similar?
Old May 4, 2006 | 02:58 PM
espimax's Avatar
that looks like it will work. but almost $600 for it. i don't know.
Old May 4, 2006 | 03:08 PM
mjk's Avatar
mjk
Head shot!!!
that would b nice for high boost/ nitrous. wouldnt need to gap closer...
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
