4th gen vs. 5th gen SC kits
Old May 4, 2006 | 11:06 AM
JustMaxin96's Avatar
Hay Guys,
I am thinking about buying a 01 AE and transfering my SC from my 96 to the 01. I know this is possible and the plate will bolt to the timing chain cover but what are some differences that I should be aware of if any? Any info would be appreciated.
Old May 4, 2006 | 11:24 AM
chris'smax's Avatar
Originally Posted by JustMaxin96
Hay Guys,
V2 plate bolts right up. I bought my kit from a 4th gen guy
Old May 4, 2006 | 12:45 PM
thanks Chris, so no differences at all? What about the charge pipe?
Old May 4, 2006 | 12:47 PM
chris'smax's Avatar
all you will have to do is move your maf to the inlet side of the blower and put a section of pipe in place of where your maf was on you 4th gen. Or you could just buy my charge pipe
Old May 4, 2006 | 12:52 PM
ahh nice! you still have it? You should have that shop you are working with produce IC kits. Oh yeah do you have to recirc. the BOV on the 5th gen? Thanks again Chris, I hope I get this AE its pretty hot.
Old May 4, 2006 | 02:08 PM
ptatohed's Avatar
Licensed to Spell
I forget what the stock 5th gen power steering coolers are like, but if they are a joke like the '98/'99 Max's, you may need a '95-'97 stock PS cooler or an aftermarket cooler. You'll also need to get a new C.A.R.B. sticker (if you care/need). I 'think' that's it. Also, keep in mind how delicate the 5th gen. MAFs are. Good luck.
P.s. Mhadford is selling his 5th gen. intake piping I believe.
Old May 4, 2006 | 05:23 PM
chris'smax's Avatar
actually i haven't had any problems w/ the maf. If you run it on the inlet side of the blower it is perfectly fine. I just reused my stock power steering cooler and it works like a charm.
And yes, if you don't have a emanage i would recirculate the bov.
Old May 5, 2006 | 06:49 AM
thanks so much for the help guys. I will keep you posted if I end up with the new car!
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
I<3 A32's
Sep 10, 2015 11:07 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
