Turbo Install In progress
Old Apr 29, 2006 | 01:50 PM
  #41
SouthFlMaxTech's Avatar
Getting Really close to finnaly hearing my car running again.. things left to do..
Intake air temp sensor,
ECU (if jim wolf ever returns it)
Oil return pump.. ships out monday
http://i76.photobucket.com/albums/j1...9/100_1185.jpg
http://i76.photobucket.com/albums/j1...9/100_1178.jpg
http://i76.photobucket.com/albums/j1...9/100_1180.jpg
http://i76.photobucket.com/albums/j1...9/100_1181.jpg
http://i76.photobucket.com/albums/j1...9/100_1182.jpg
Old Apr 29, 2006 | 02:14 PM
  #42
Nealoc187's Avatar
SLOW
How long ago did you order your jim wolf ecu. Traditionally it takes between 10 and 12 weeks to get them back, almost always more than 8 at least.
Old Apr 29, 2006 | 03:12 PM
  #43
D-Bo's Avatar
Droppin logs
Nice setup, keep us posted with your development!
Old Apr 29, 2006 | 04:57 PM
  #44
Nismo3112's Avatar
Custom User Title
Nice work. I like the location of the turbo.
Old Apr 30, 2006 | 06:45 AM
  #45
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
for some reason looking at clearer pictures now the location bothers me a bit in a bad way dont know why yet, when i realize it ill post again.
Old Apr 30, 2006 | 07:44 AM
  #46
cld12pk2go's Avatar
What pump did you order for the oil return?
Old Apr 30, 2006 | 07:48 AM
  #47
I wasnt sure what one to order.. but i found a guy that makes them.. he takes regular pumps and modifyes them for oil return.. so that is what i got comin dont know how the quality is yet but hopefuly good
Old Apr 30, 2006 | 07:50 AM
  #48
http://westech.home.mindspring.com/propages/scvpump.htm
that is a link to what i bought!! tell me what you all think..
Old Apr 30, 2006 | 08:10 AM
  #49
I30tMikeD's Avatar
Hard to tell how low the turbo is mounted. But it's right at the spot where if I bottom out I hit my feed pipe.
Old Apr 30, 2006 | 08:41 AM
  #50
the turbo is quite low but it is higher than the lowest point of the trans/engine.. and i have yet to scrape them!
Old Apr 30, 2006 | 06:03 PM
  #51
cld12pk2go's Avatar
That scavange pump looks like a very common pump used for many DIY alky injection systems (goes for about $70 new online); however, I am not sure what mods he has done to it.
It should work nicely though.
Old May 3, 2006 | 07:57 AM
  #52
gtr_rider's Avatar
192.168.1.1
wow, that is stealth once you put the covers back on..
Old May 3, 2006 | 05:03 PM
  #53
Oil pump comes tommrow!!! but STILL WAITING ON ECM going on 3 weeks!!!
Old May 3, 2006 | 05:08 PM
  #54
Nealoc187's Avatar
SLOW
You aren't going to have your ECU for another month and half at least... 10-12 weeks is normal, 8 weeks minimum. JWT is awesome like that.
Old May 3, 2006 | 07:04 PM
  #55
Lol I sure hope not but I have a feeling that you are right from what i read!!
Old May 3, 2006 | 07:17 PM
  #56
cld12pk2go's Avatar
So why are you getting the JWT ECU anyways?
Just call them and say to return your ECU unmodded and get the EU and be much better off tune wise without the crazy wait.
Old May 3, 2006 | 09:58 PM
  #57
96_vqmax's Avatar
This is a really nice and clean setup you got there,I did plan to do my forward turbo the same way,when I hook up my reverse y pipe turbo,I was looking under the motor and see if there was any room for the forward turbo setup,but found the room was limit to either use real small pipe or modify the front mount,looking at your pic,you only modify the front mount right?So I see your feed oil line come from the back and through the front,couldn't really see it clear in the pic,but is the feed line higher than the drain line or they are level?Keep up the great work and keep us update.I hope you will get your ECU soon,LOL.
Old May 4, 2006 | 03:31 AM
  #58
yeah i had to mod the hell out of the front mount.. to make it all work.. but nothing is lower than the cross member.. and the oil supply line comes fromt he sender unit..to the turbo.. up over the trans... now the return is a different story.. i am waiting on my pump should be here today.. so i gotta splice that in-line and wire it up.. i wanted people to open the hood and not see a huge turbo there.. also with it down low like it is should stay quite cool! but i gotta be careful of road debri hitting it.. but i figure it this way.. the oil pan and the bottom of the trans are 1/2 of a inch to a 1in lower than the turbo.. and well i still have my oil pan! I am hoping for it to run good but i know there are gonna be un-forseen prolems.! just the way it goes.. I have spent countless time just cutting and fitting pipes! well thanks for the nice coments and more pics to come!!!
Old May 4, 2006 | 04:12 AM
  #59
Blu's Avatar
Blu
the tits
I think you are going to regret not listening to others about ditching the JWT ECU idea. They have had it 3 weeks and I can pretty much guarantee they haven't touched it yet. I would call and get them to send it back and get a Emanage U to do all the tuning with.
Old May 4, 2006 | 03:31 PM
  #60
well I read the thread on the emanage.. and people not getting it to work with the cam/ crank sensor.. I have put a ton of though into this project.. and well I will prob regreat sending it to them.. but i wanted a higher red-line and from what i read the e-manage cant do that.. (i may be wrong) and I am not confitant in the e-manange.. how to tune it.. I am sure i could figure it out. well I even asked jim wolf about what people said.. and i was told that most people dont listen to them and run different injectors that what they specify.. but like i said i dont know if that is true just what i was told! so i am sure that in like 4weeks or so when i get my ecm it wont work and it will be all wrong.. from what i hear.. but some times you gotta learn a lesson the hard way.. I would rather not make as much power as i should VS run to lean and melt a pistion...
Old May 5, 2006 | 03:21 AM
  #61
cld12pk2go's Avatar
The EU can adjust redline now. It can also control AFR and Ign Timing.
Old May 5, 2006 | 07:02 AM
  #62
Preach on bortha
Old May 8, 2006 | 05:07 PM
  #63
Ok did some more work tonight got the oil pump in and wired up.. so I am about 95% done!!! should be this week!!
http://i76.photobucket.com/albums/j1...9/100_1269.jpg
http://i76.photobucket.com/albums/j1...9/100_1274.jpg
http://i76.photobucket.com/albums/j1...9/100_1275.jpg
http://i76.photobucket.com/albums/j1...9/100_1271.jpg
Old May 8, 2006 | 06:15 PM
  #64
diymaximakid's Avatar
nice setup.
Old May 9, 2006 | 05:18 PM
  #65
maxgtr2000's Avatar
KH3 by popular demand
That looks pretty impressive!!
Old May 9, 2006 | 07:11 PM
  #66
Bags's Avatar
VG Ridah's Biatch Hoe
I like it
Old May 9, 2006 | 07:59 PM
  #67
See now sience i got some good pics.. everyone likes it.. I am just unsure what it is gonna do.. I have spent countless hours on this.. and well i am soo exticted.. if i would of bought a kit i would of been done a long time agao.. but then how would i be different? haha
Old May 10, 2006 | 03:25 AM
  #68
cld12pk2go's Avatar
I would put some oil in the turbo's center section and spin it around a little prior to startup.
Just so the bearings aren't dry at startup (just incase you haven't thought about this).
Old May 10, 2006 | 08:20 AM
  #69
ajcool2's Avatar
Yeah I think the pics do help to understand your setup better. I dont know the first thing about hooking up a turbo but I will be using your pics to understand it a little better. I didnt think you would be able to hide the intercooler but you did perfectly. The only thing someone may notice is the red piping. Very nice work on your setup and I'll be following it to the end.
Old May 11, 2006 | 05:42 PM
  #70
Well got the greddy exhaust today.. installed tonight had some fitment issues but not un-common.. got it all worked out with my hi-flow RT cat and well just waiting on jim wolf to do there majaic.. I am gonna call them up monday and *****!! and see what they say!!
Old May 13, 2006 | 03:41 PM
  #71
Well it is 7pm sat night just got it running with a ecm from a 1995 max auto.. the ecm actually works good with the configuration but!!! The turbo is NO GOOD it burns oil now.. ( the oil is coming out of the exhaust side of the housing) and it wont boost over 4psi even with the waste gate actuator vacume line disconnected.. this sucks.. but what can you do.. I am gonna have to have it re-bulit.. well if anyone has any ideas on what to do let me know thanks!!
ps I do have a oil return pump and it is working good (i checked that)
Old May 13, 2006 | 06:45 PM
  #72
wasnt it a new turbo
Old May 13, 2006 | 07:06 PM
  #73
Nismo3112's Avatar
Custom User Title
That turbo looks brand new. Are you sure you dont have your feed and returns criss crossed?
Old May 13, 2006 | 08:42 PM
  #74
yeah i got the feed lines and the return correct.. the problem is that when i turn off the car all the remaining oil drains into the turbo and then upon start up is when it all burns out.. so what i need to do is have my return pump on for like 15-20 seconds after engine shut off to remove the rest of the oil.. and for the no boost I have no idea... the only thing i can think is that the housing that the plunger seals aginst is warped? I am not sure but something i am gonn ahave to check out!! but where the turbo is it is hella easy to remove!! that is a good thing.. but even with 3.5-4.0 psi this car feels great I am soo happy with how it is right now.. I cant wait until i get to double that!! well more to come when i find out more!!!
Old May 13, 2006 | 08:44 PM
  #75
cld12pk2go's Avatar
Was this a cheapo ebay turbo (~$300-$350)?
Several of these chinese turbos are known to be of very poor quality (usually poor balance) and eat themselves in very short order...
However, in your case it sounds like you have two issues.
One is a bad oil seal, which is leaking oil into your exhaust housing. This could be from too much oil flow feeding to the turbo (pushes past the seal), the oil not being pumped out sufficiently (you said you checked this one), or from the seal being bad initially.
Also, you are not able to acheive over 4 PSI even without a pressure signal from the manifold. This sounds like the wastegate is leaking (weak spring?) or you have some bad exhaust leaks pre turbine.
  #76
Bags's Avatar
be easy on dumping the turbo.. does the turbo have a check valve in it for the feed line? what size feed line? are you sure oil is draining ok form the turbo? How do you know?
What exhaust size? if the exhaust is to small(STOCK) your boost will be limited by the back pressure.. try open exhaust?
Old May 13, 2006 | 08:58 PM
  #77
well i do have the correct resztrictor.. and like i said b4 the oil buring is cause by oil sitting in the turbo after i turn the car off i just need to run my oil return pump after i turn the car off.. so i got a timer relay comin for that.. and for the other problem.. I know it isnt a weak spring on my wastegate actuator.. it is just leaking past the waste gate inside.. the turbo was brand new garrett t3/t4
Old May 13, 2006 | 09:28 PM
  #78
well all the more reason to get an external waste gate shouldn't be to hard to adapt to it
Old May 14, 2006 | 10:23 AM
  #79
|Bijan|'s Avatar
UCF Lexus
Kenny what kind of radiator do you have?
Old May 14, 2006 | 10:27 AM
  #80
cld12pk2go's Avatar
I wouldn't think that oil not under pressure should ever leak through the seals...If it could then it would only leak worse during times when it is pressurized.
I would think the seal is questionable.
