Quick SC Belt question
Old May 1, 2006 | 07:59 PM
TJ_Max's Avatar
Paradox Systems Vendor
I have a gatorback belt on my SC. I want one for the 2.87". Where can I pick one up? 3 Autozones didn't have it and I couldn't find it online. It is belt #K060703. I refuse to settle for just some generic belt or gates belt after the flawless performance of my gatorback . Thanks.
Old May 1, 2006 | 08:41 PM
Flava_24/7's Avatar
Boosted Panda
I got mine from Auto Zone,
Heres the info for the Gatorback belt.
2.87................4060690 6PK1755 69 "--69 3/4"
The part number you have is for the Gates belt.
Old May 1, 2006 | 08:43 PM
matty's Avatar
I went right to Goodyear. Those Goodyear service places you see everwhere. They have them in stock
-matt
Old May 1, 2006 | 09:15 PM
TJ_Max's Avatar
Thanks fellas.
Old May 2, 2006 | 09:48 AM
Or have Autozone order you one. Only takes 2-3 days.
Old May 3, 2006 | 04:46 PM
According to post #7 in this thread, the number is different. (3.00 to 2.87 - K060703
http://forums.maxima.org/showthread.php?t=291403
and post #3 in this thread...http://forums.maxima.org/showthread....ght=belt+sizes
Ptatohed tried the number for the 2.87 in the sticky, and Autozone can't pull that number up.
In another thread I just found, it lists the numbers Flava lists. Moderator, please fix the info in the belt sticky....
Thanks Flava flav
Old May 3, 2006 | 05:12 PM
Flava_24/7's Avatar
Boosted Panda
Thanks Flava flav
I went to AutoZone, and gave them this part number 4060690 6PK1755 69 and they had it. That same part number was on the actual packaging as well.
I was told that belt will fit the 2.87 and the 3.0 pulley.
I currently have it on the 3.0
The part numbers listed are different because the 4060690 is the GoodYear gatorback part number, and the K060703 is the Gates part number.
http://www.goodyearbeltsandhose.com/...098Rw:uur6d6ic
http://www.gatespowerpro.com/Comerge...TOKEN=56956622
Old May 3, 2006 | 05:28 PM
ewuzh's Avatar
Yup. Autozone carries Goodyear Gatorback. 4060690 is the belt I am using.
Another something to clarify:
Assuming the same SC pulley diameter, do V1 and V2 plates use the same belt lengths?
Old May 3, 2006 | 05:30 PM
matty's Avatar
I'm going to have to say NO
-matt
Old May 3, 2006 | 08:31 PM
TJ_Max's Avatar
No, V1s and 2s do not use the same belt lengths from what I gather. I have a V2 plate and I just bought the gatorback 4060690 from an auto parts store. Using this on my 2.87. I should have no problems......I hope....
Old May 3, 2006 | 09:05 PM
chris'smax's Avatar
I couldn't find the gatorback belt here in town so i just went with the gates blet. I just hope that thing doesn't me.
Old May 3, 2006 | 09:07 PM
TJ_Max's Avatar
You know damn well any of us would have shipped ya one.
Old May 3, 2006 | 09:08 PM
Ghase's Avatar
You Jacka$$, what did I tell you last Saturday?????? Do you want me to pick you up one when I come over???? ......
Old May 3, 2006 | 09:14 PM
chris'smax's Avatar
$hit man i am ready to get my car back, i sure as hell wasn't going to wait on a belt. Its not going to be on there for more than a couple of months anyways. I still have my 2.62 pulley in my closet
thanks for the offer though
Old May 3, 2006 | 09:21 PM
TJ_Max's Avatar
Jack@$$ did you read my post above?
"I have a V2 plate and I just bought the gatorback 4060690 from an auto parts store. Using this on my 2.87. I should have no problems......I hope...."
Old May 3, 2006 | 09:22 PM
TJ_Max's Avatar
I forget, you have v1 plate or v2?
Old May 3, 2006 | 09:29 PM
Ghase's Avatar
My bad Webster, it's not that I didn't read, but actually I didn't see it.
Old May 3, 2006 | 09:48 PM
ewuzh's Avatar
If that's the case, then you need the 6 rib 70.3" length belt. The 69.0" belt is the belt I am using for my V1 w/ 2.87. It might be a tight fit for you
Old May 4, 2006 | 07:31 AM
Look at this link....http://forums.maxima.org/showthread....ght=belt+sizes
Post #7 I thought the numbers were the same for Gates and Gatorback, only the "4" or the "K" in the front changes.
Old May 4, 2006 | 07:55 AM
ewuzh's Avatar
My understanding is that the "4" or "K" in front just tells you whether it's a Gates or Goodyear belt, but the belt lengths for a v1 plate and v2 plate are different.
"060" = 6-rib
"690" = 69.0 inches in length
The belts listed in the belt sticky are Gates belts for people with v2 plates.
The Goodyear belts for people with v1 plates are listed in this thread:
http://forums.maxima.org/showthread.php?t=455158
So if you want a Gates belt for a v1 plate w/2.87 pulley, then I'm sure you can ask for a K060690.
Old May 4, 2006 | 08:46 AM
Flava_24/7's Avatar
Boosted Panda
The part numbers are different.
If you go to Goodyears site, put in the Gates part number and search for it, it will give you the Gates part number for there belt in that size as well as the GoodYear part number for the gatorback belt.
http://www.goodyearbeltsandhose.com/...avdJU:uur6cg6k
By looking at the GoodYear site, it seems that
The K060703 Gates belt is the Gatorback 4060705, Gator Back metric part number 6PK1790
I tried searching the Gates site by GoodYears part number and got nothing.
Looks like we may need an update on belt sizes.
Old May 4, 2006 | 02:33 PM
ptatohed's Avatar
Licensed to Spell
Now I am thoroughly confused. I have my 2.87" pulley sitting in my garage waiting install. I just need to know what Gatorback belt to buy (V2 plate).
Old May 5, 2006 | 09:58 AM
TJ_Max's Avatar
Werd, wut in the fawk is going on here? LOL. I got a damn Gatorback belt for my 2.87". It is the 4060690. Am I good or not? This is going on this weekend probably. V2 Plate.
There was no 69 3/4" belt length, so they gave me the 690.
Old May 5, 2006 | 10:01 AM
TJ_Max's Avatar
Dammit. You might be right. Waiting for an official belt list for gatorback, and gates. I need to know if I need to exchange it or not. Someone let us know, V2 plate, GATORBACK BELT with 2.87" pulley. Why go gates if gatorback is better anyway?
Old May 5, 2006 | 10:10 AM
ewuzh's Avatar
Originally Posted by ejj
FYI - its not too difficult to get one from the other...
If you have a gates number K060710 to get the goodyear #:
4060710
4 - Represents the same thing Gates' 'K' does (not sure what that is though)
06 - #of ribs
071 - Inches
0 - Tenths..
So, if you needed a K060703 for your 2.87" pully, you'd ask for a 4060703 goodyear gatorback belt.
It will be a tight fit. You need a 70.3" length belt, or something close to it like a 4060705 because Goodyear does not make a 4060703 belt.
NAPA (Gates) also has V-ribbed belts very similar to the Gatorback belt design.
Old May 5, 2006 | 10:14 AM
TJ_Max's Avatar
V2 plate 2.87" pulley = Gatorback Belt #4060705
4060703 would be ideal, but they don't make them. Ok, thanks. Anyone confirming this?
Old May 5, 2006 | 10:16 AM
ewuzh's Avatar
Thanks Flava flav
Autozone can't pull up K060703 because that is a Gates part number. Ideally you'd be looking for a 4060703, but the closest thing Autozone/Goodyear carries is a 4060705.
Old May 10, 2006 | 01:39 PM
ptatohed's Avatar
Licensed to Spell
So what's the answer? (2.87" pulley, V2 plate).
Old May 10, 2006 | 01:52 PM
TJ_Max's Avatar
I went ahead and bought a Gatorback belt# 4060705. For my 2.87", V2 plate.
I think i'm gonna be a man and take the damn thing off tonight. I'm so freaked out about snapping a bolt upon removal or something.
Old May 10, 2006 | 08:08 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Don't worry about it. You will know exactly how much of a PITA the V2 plate can be. If you need a replacement bolt, just go to ACE and get the same grade/length/size bolt. As for the FHCS bolts, don't strip those.
The one that secures to the bottom of the plate/tensioner assembly sucks major ***. The small bolt is easier to get in if you can get the pulley off and have a gear wrench, which is the greatest set of tools that you can buy yourself (if you don't have them already.)
Old May 10, 2006 | 08:14 PM
slimer's Avatar
The NAPA one is not exactly like the Gatorback. You will lose a rib of one of those.
Actually I got the wrong belt at the track last April and have been running a 5-rib belt for over a year. Its actually kind of nice because if its misaligned, It has one pulley rib to jump so I can just loosen, fix and retighten if I notice a problem. I caught it doing that last fall. No problems since.
One thing that I can suggest is to invest in the ASP pullies. They do a great job staying in place. I just noticed that there is slight surface rust on it, but we had a salty winter.
Old May 10, 2006 | 08:29 PM
LatinMax's Avatar
4060690 it is a little snug but that is what I am running on mine
Old May 10, 2006 | 08:35 PM
LatinMax's Avatar
Belt sizes for V2:
Gates (starts with K) Gator (starts with 4)
3.60 to 3.33 takes K060710 4060710
3.25 to 3.12 takes K060705 4060705
3.00 to 2.87 takes K060703 4060690
Old May 11, 2006 | 07:26 AM
ptatohed's Avatar
Licensed to Spell
:o)
Originally Posted by LatinMax
Belt sizes for V2:
Now I am even more confused.
So the 3.0" to 2.87" belt size has a different number after the K/4??
Old May 11, 2006 | 08:00 AM
TJ_Max's Avatar
Ok well I got it off . I know exactly what you were talking about there. But I got so lucky. The previous owner of the plate modified the plate for easy removal and installation. Take a look at the bottom hole where the bolt through the tensioner was supposed to go:
They grinded it down completely. I didn't have to loosen/remove the tensior bolts at all, the plate slips right over it. Never had any belt issues with this either. This plate was also grinded down so I could use a 2.87 pulley.
Anyway, this was my first time pulling my own blower/plate off. It took me about an hour. I was inspired by some of you guys to just go do it. Now, we need this V2/2.87" belt question answered. Tonight i'm slapping on the 2.87" and i'm using the gatorback 4060705. My fear of shredding belts is greatly reduced since I can change out belts in no time now. .
I guess i'll be the test dummy for the 4060705 v2, 2.87" combo? We have one 2.87" saying it'll work, where are the rest of the 2.87" v2 guys? I'll post up my results tonight. Or tomorrow morning.
Old May 11, 2006 | 08:40 AM
ptatohed's Avatar
Licensed to Spell
Awesome. Thanks for being the guinea TJ. Good luck.
Old May 11, 2006 | 08:44 AM
slimer's Avatar
I knew you could do it!
Old May 11, 2006 | 09:56 AM
chris'smax's Avatar
I am still using the 2.87 and i am running the size that was suggested in the stickies. It was a bia to get on there
Old May 11, 2006 | 12:46 PM
TJ_Max's Avatar
Looking for the gatorback number for the 2.87 on the v2 plate. Your flimsy gates belt is just gonna snap , lol. J/k.
Old May 11, 2006 | 06:02 PM
LatinMax's Avatar
once again GatorBack 4060690 the 4060710 WILL be too long and you will be pissed.
