GI: Brand New Custom Made VQ30 Eagle Rods
Old Feb 26, 2007 | 02:37 PM
  #41
nismology's Avatar
Originally Posted by TurboS13Hatch
The 6spd doesn't use a trans bracket.. there's a bracket that bolts to the back of the block with 4 bolts, then, attaches to the rear cross member mount.. but nothing attaches to the trans itself. So, there shouldn't be any issue there.. unless the older 5spd is attached to the 4th gen rear mount. In that case.. you would have to make an adapter.. or try to use a 5th/6th gen rear engine mount.
Travis
I have sitting here in front of me the A33B tranny mount and bracket. The bracket bolts to the frame, the mount bolts to the tranny, and the through bolt goes through the mount and "ears" of the bracket. Same as the A32, except the bracket is bolted-on as opposed to welded. To me welding it to the frame is the better option compared to drilling/tapping when installing it on an A32.
Old Feb 26, 2007 | 02:42 PM
  #42
nismology's Avatar
Originally Posted by GodFather
The JWT/Fidanza flywheel/clutch combo, you mean from the 6 speed, right? I have the 6-speed's stock flywheel and clutch, guess that'll be fine. Is it possible to still use the 4th gen flywheel/clutch assembly, probably so with them T/O bearing spacer, right? If that's the case, I get to skip having to buy the CPS ring from you, correct? All I have right now is the 6-speed tranny, flywheel, and clutch all stock. So I couldn't figure out what I'd need internally. Thanks for the help.
-Peter-
What you're saying makes sense, but keep in mind that those that have used the T/O bearing spacers so far have used them with RWD Z33 tranny's. Don't know if that changes anything, but it's something to consider.
Old Feb 26, 2007 | 09:29 PM
  #43
TurboS13Hatch's Avatar
There's a bracket from a A33B, which bolts up to the block, and then to the rear engine mount on the Spec V. This is the same style of mount that's on a Maxima..
Travis
Old Feb 26, 2007 | 09:43 PM
  #44
nismology's Avatar
Who said anything about a motor mount? I was talking about the tranny mount/bracket, which you said didn't exist.
Old Feb 26, 2007 | 09:53 PM
  #45
You're talking about the driver's side mount? I thought you were saying that there was a rear trans mount.. some of the older 5spd Sentra's have a trans mount that bolts up to the rear isolator. I didn't know if the A32 had the same setup or not..
Old Feb 26, 2007 | 09:59 PM
  #46
nismology's Avatar
Reading through my post i don't see what the source of the confusion was but oh well...
Old Feb 27, 2007 | 06:56 AM
  #47
Well, I mentioned in my post above that a trans mount was needed.. I meant the driver's side mount. I was confused, and thought that you were talking about a rear trans mount.. which some of the older Sentra's had.. which also had 5spd's.. That's why I said that there wasn't a trans mount. Completely my goof.. sorry for the confusion.
Travis
Old Feb 28, 2007 | 06:58 PM
  #48
I should have these next week.. I'll start a new thread with build pics and info..
Old Mar 2, 2007 | 08:44 PM
  #49
Any update on shipping these?
Old Mar 3, 2007 | 10:18 AM
  #50
SpeedCrazie's Avatar
Got my 2nd part in yesterday, shipped today via 2 day fed ex.
PM Sent.
JP
Old Mar 3, 2007 | 10:19 AM
  #51
These Are Sold
Mar 12, 2020 12:06 AM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
0m3nc0w
Sep 11, 2015 05:21 PM
carid
Sep 9, 2015 05:06 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
