Using Electronic boost controller to control boost w/ SC
Old May 28, 2006 | 02:19 PM
chris'smax's Avatar
I just bought a Profec E-O1 boost controller and i am trying to devise a way to control my peak boost w/ it. I bought it to program my emanage w/ since i am sick of using my gf's $hity laptop and i figured i might as well use all of its features. Now was originally planning on using a wastegate just like on a turbo setup, but my buddy was telling me you can also hook them up to your BOV to serve the same purpose. He tried explaining it to me but i really wasn't paying attention since i was aggravated w/ the car. Is this possible?
I know that this could cause a issue since my maf is on the non charged side, but i figure i can make adjustments in the emanage to compensate for the air that is dumped out.
This will not be going on until i get the car up and running smoothly because the last thing i need is to create a bigger headache for myself
Old May 28, 2006 | 06:24 PM
LatinMax's Avatar
I don't think it can be done since the boost is driven by the speed of the engine and not by exhaust. So you can't force a waste gate to close more or longer to raise boost at lower rpm's.
Old May 28, 2006 | 07:32 PM
chris'smax's Avatar
The purpose is to use the smaller 2.62 pulley since the boost will increase the amount of boost seen early in the rpm band as opposed to the 2.87. I am going to use the boost controller function to control the opening point on the wastegate.
All i am trying to avoid is getting to much peak boost. I don't want to run over 11 psi on this motor for the time being.
Old May 28, 2006 | 10:10 PM
Broaner's Avatar
2060lbs and falling...
I really gotta ask. Why not go turbo?
I've been wondering that for a long time with all you guys running more than 13lbs. I can understand wanting instantaneous power from the blower but I think that kinda gets negated by traction issues when you're running that kind of power. I'm not being negative here. I just want to understand why it doesn't make sooooo much sense to switch to turbo.
Old May 28, 2006 | 10:11 PM
ewuzh's Avatar
This is interesting and seems very possible to do. Or you can try custom spring rate for the BOV that leaks boost at a certain PSI.
Old May 29, 2006 | 03:21 AM
chris'smax's Avatar
that may happen, but at this point i really don't want to deal w/ the switch. I am still in college and I drive my car everyday and i just don't see the tubo as something that i can rest easy with. The SC is simple and reliable and very low maitenance.
Plus i want to save my turbo experience for when i graduate. I want to get a Supra or a 240 and just go crazy w/ it
Old May 29, 2006 | 03:23 AM
chris'smax's Avatar
yeah i remember maxi-overdose did that w/ the BOV. I just wanted to use the boost controller so i have full control over the amount of boost and so i can raise it if i am feeling frisky
Old May 29, 2006 | 08:03 AM
iansw's Avatar
Many of us are waiting for Mingo to get some forward facing piping made.
Old May 31, 2006 | 05:34 PM
chris'smax's Avatar
anymore thoughts on using the bov controlled by a Electronic boost controller to vent peak boost?
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
