Anybody done a turbo setup like this before
Old Aug 1, 2006 | 07:12 PM
Fred Allen Burge's Avatar
I've always wanted to see a Maxima setup like this, anyone done this yet? Seems like an obvious solution once you look at it.
Fred
Old Aug 1, 2006 | 07:18 PM
mforrest100's Avatar
Why can't I see in the links? Each one is the same thing. Just an engine shot of a VQ35.
Old Aug 1, 2006 | 07:24 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
thats pretty much what the 3rd gen guys have at least been doing for a while now(I know Mtcookson) had a very close setup to that with the two manifolds meeting right over the transmission and the turbo mounted there as well
Old Aug 1, 2006 | 07:46 PM
mtcookson's Avatar
Yeah, I did a setup like that. Works pretty well but I want to redo my front manifold and crossover so that it could flow even better. What's nice about it is the setup makes it relatively easy to do an equal length setup, which should allow for quicker spooling than a regular "constant pressure" setup. I still haven't decided if I'm going to finish that design yet or not though.
Old Aug 1, 2006 | 08:58 PM
sandeep's Avatar
nice set up yo
Old Aug 1, 2006 | 10:20 PM
maxmaxima91's Avatar
mines basically like that.. places the turbo right over the trans
Old Aug 2, 2006 | 05:57 AM
Nice! Happen to have any more pics of the manifolds? I'm thinking of the same setup but facing forward on my car.
Fred
Old Aug 2, 2006 | 06:24 AM
Heres alot of pics of the setup when i first installed it. http://pg.photos.yahoo.com/ph/maxmax.../ph//my_photos
Most of my updates are in this thread
http://forums.maxima.org/showthread.php?t=482180
Old Aug 2, 2006 | 08:10 AM
Excellent work man, I don't know how I've missed your project for so long! What type of bends did you use for your exhaust manifolds, thin wall or the thick wall "weld els"?
Fred
Old Aug 2, 2006 | 09:12 AM
I used thinwall steel and ceramic coated it.
Old Aug 3, 2006 | 05:04 AM
pawnstar12's Avatar
BUY MY CARS PLEASE!!!
it looks like 3rd gens can only pull it off
Old Aug 3, 2006 | 05:44 AM
Broaner's Avatar
2060lbs and falling...
What motor is that? Looks like a really neatly designed package. You aren't contemplating doing this are you Fred? I always thought you wanted to keep the stock firewall intact.
Do you guys have your motors solid mounted to have the header directly supported to the chassis?
Old Aug 3, 2006 | 05:56 AM
I believe it was a SAAB motor if I remember correctly. I'm thinking about doing it but flipped to the front of the motor for a front mount turbo.
Fred
Old Aug 3, 2006 | 06:35 PM
Fred,
I picked up the book today just for your article. Read thru half. Congradulations on the publication.
Old Aug 3, 2006 | 07:13 PM
Broaner's Avatar
Ah yes the new Saab. I remember reading about those. I liked the 4 bangers a lot better. This new motor makes the same power stock as the old 2.4l 4. Saab has been doing some interesting stuff lately. I've always said if they made a RWD model they'd easily be able to compete with mid level Benz and Bimmers. The Aero model 9-5's have that RWD look too.
Anyway, I was also thinking of doing something similar. Only problem on the VQ is that the alternator is right were the pass side exhaust mani should route. I was thinking a center mounted turbo would be great for spool but fitting a bit unit between the timing chain and the rad could be challenging once piping is accounted for.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
09maxshawn11
Sep 30, 2015 10:28 AM
