Mevi tick tick tick?????
Old Sep 12, 2006 | 12:27 PM
Stillen Maxima's Avatar
Pay to Play
I took my blower off today to fix an oil leak thats been killing me right on the timing chain cover and just have to do something about it. Well I put the stock belt back on and started up..........i let it run for a couple min then rev'it up and noticed a weird ticking coming right on top of the mevi GREAT!! at idle the car sounds normal, really quiet but when i rev it up a little the ticking sounds comes and goes away as the rpm's drop. I dont think this is normal. I dont know how long its been there because with the sound of the blower u cant tell anything. Let me know if anyone has an idea what this could be?
Albert
Old Sep 12, 2006 | 01:09 PM
matty's Avatar
First pop the cover off and see if all the screws are there and in tacked. Possibly could have lost a screw down into the engine, then your F*cked.
or two, it could possibly by the butterfly valves vibrating with the engine and making the noise. Mine used to be loud until you touch the rod and it quited up. I would def check the screws RIGHT AWAY
-matt
Old Sep 12, 2006 | 02:31 PM
RA030726's Avatar
I'm nutty for Nissans
^^^ sounds just like mine. If I pull the actuator ever so slightly the tick goes away. I think its the pulses of air hitting the butterflies. I probably should check under there any how.
Old Sep 12, 2006 | 02:39 PM
BlackCat's Avatar
RIP '98 Maxima SE
I don't even have a mevi on my engine and yet I hear a tick, tick, tick around the throttle body as well. This is happening, even with my supercharger being offline. Must be the butterfly valves.
Old Sep 12, 2006 | 02:49 PM
RA030726's Avatar
well the evap volume control clicks too, its the large black (97+) or metal/brown (95/96) device on the IM. Its got 2 rubber hoses on it and a large 6 or 8 pin plug.
Old Sep 12, 2006 | 03:03 PM
Pay to Play
Well i guess im gonna have to remove the cover on top of the mevi to c whats missing or what not.
Old Sep 12, 2006 | 03:04 PM
SMX95's Avatar
Yes, you can check them but a simple test to do is slide the bar that holds the butterfly side by side. you will hear it change. Its just the fact its rubbing against the port. I been having this problem since day 1 and I used lock tight RED.
Old Sep 12, 2006 | 03:22 PM
Pay to Play
Thank to everyone for ur help. Im at work at the moment and will check my POS mevi tomorrow morning. I will post with updates once i take that cover off
Old Sep 18, 2006 | 08:35 AM
Pay to Play
I took the cover of the mevi off and everything looks to be in its place.So WTF?? After i had put it together I went ahead and turned the car on and actually put my ear on top of the mevi and heard that the butterflyes are the ones that make the ticking noice when the engine is rev a little. Is this something normal?
Old Sep 18, 2006 | 10:09 AM
RA030726's Avatar
Like I said, mine does it too. It seems to do it until you physicly move the actuator rod slightly. It kinda sounds like the injectors actually.
Old Sep 18, 2006 | 10:25 AM
Pay to Play
Thank you!!! I did exactly the same thing. I physicly moved the actuator and rod slightly with my finger and rev'd it and sound went away. HHmm weird mevi sound effects.
Old Sep 19, 2006 | 04:51 AM
cardana24's Avatar
Blown
now fix your oil leak and you are good to go. Glad you figured out what the noise is
Old Sep 19, 2006 | 11:15 AM
Pay to Play
Thanks carson, Gonna get to work on the other issue of the leak. Other guys here have the same sound on top of the mevi so i guess its normal.
Old Sep 19, 2006 | 02:00 PM
OOmaxSE's Avatar
Glad you got the problem fixed, I thought it was normal. I hear a ticking near the IM also, can someone point me out to this actuator rod? Thanks.
Old Sep 22, 2006 | 06:45 AM
sean05's Avatar
i had the closest call with my mevi a while back. One screw actually came out and it was sitting in the actually mevi and never fell down the hole of doom. it definitely was a clooooose call.
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
ColdCananda
Sep 20, 2015 10:45 PM
