whats the belt size for v2 with 3.125 pulley
Old Nov 26, 2006 | 10:44 PM
trialt's Avatar
i have a v2 kit with a 3.125 pulley and ive tried the 4060705 belt which is listed as the correct size for the v1 but its too small. and ive tried a 4060745 and its too big. i dont know what size it actually is. please help someone..
Old Nov 27, 2006 | 09:04 AM
abci30's Avatar
oh noes!!!!1111
4060705 is the correct size. Are you sure you lined up the belt correctly, maybe it was stuck on something when you tried it the first time. I know the belt sometimes wraps itself around the oil filter since its pretty close and sticks out.
Old Nov 27, 2006 | 09:12 AM
abci30's Avatar
oh noes!!!!1111
you are using the modified tensioner plate/assembly right? Did you make sure you wrapped the belt the right way on the actual supercharger pulley making sure you are routing it the right way (not around any plate/sc post).
Old Nov 27, 2006 | 10:02 AM
trialt's Avatar
yes i made sure.. ive been trying for 4 hrs a night for the past 2 days to make the belts fit but they dont.
Old Nov 27, 2006 | 11:25 AM
BlackCat's Avatar
RIP '98 Maxima SE
NAPA Gates belt #060695 which is 70" worked for me. This is for the 3.125" pulley on matty's V1 plate and reusing the stock belt tensioner, not the one that came with the Stillen kit. 4060705 was loose on mine as well with the stock tensioner.
Old Nov 27, 2006 | 12:17 PM
trialt's Avatar
idk if its because the v1 and v2 plates are different? but the 70.5 inch belt was too short and the 74.5 too long.
Old Nov 27, 2006 | 01:26 PM
abci30's Avatar
oh noes!!!!1111
for the v2 plate (i assume thats what you have) the 4060705 belt is the right one if you are using stock sized idler and tensioner pulley. If you are using a lexus tensioner pulley then the belt will not fit.
Old Nov 27, 2006 | 01:43 PM
BlackCat's Avatar
RIP '98 Maxima SE
The V2 plate:
and the V1 plate:
trialt's Avatar
thats probably why then.. i have the asp racing pulley
Old Nov 27, 2006 | 02:34 PM
abci30's Avatar
oh noes!!!!1111
the asp replacement pullies are stock sized.
Old Nov 27, 2006 | 02:40 PM
trialt's Avatar
well i dont understand why it doesnt fit then.. =( seems strange to me. i ran it as the stillen instructions said.. maybe certain maxima have different sized pulleys? idk...
Old Nov 28, 2006 | 03:13 AM
trialt's Avatar
lol finally got it.. it took a 710 belt
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
