i emailed vortech
Old Dec 14, 2006 | 01:04 PM
trialt's Avatar
i emailed vortech
i asked them about the marbles sound at idle with the v2 and they said if it dissapears as i go up the rpm rangwe its normal.. its just the backlash of the gears.. so he said im in the clear.. whew..
Old Dec 14, 2006 | 01:13 PM
Sweet. Now go figure out your belt problem
Old Dec 14, 2006 | 01:41 PM
trialt's Avatar
haha yea i think i got it figured out. i KNOW its something to do with how the guy put the alternator in though... ive checked everything, put the 6rib on etc and the alternator is the ONLY pulley that doesnt line up correctly
Old Dec 15, 2006 | 11:31 AM
BlackCat's Avatar
RIP '98 Maxima SE
Check to see if the pulley is loose on the shaft or if the belt is on too tight. Those two things can cause the marbles in the can noise. A loose pulley will vibrate and an overtightened belt will cause premature bearing failure. Been there, done that
Old Dec 15, 2006 | 11:48 AM
matty's Avatar
Blackcat,
You install your V1 Conversion Kit yet ??
-matt
Old Dec 15, 2006 | 12:53 PM
trialt's Avatar
thx blackcat. i think ill check if the belt is too tight.. iv already had the pulley screw come of fand redid it with loctite red.. hehe thx for the tip about the belt =)
Old Dec 15, 2006 | 12:57 PM
trialt's Avatar
oh and btw how tight should the belt be and how can i measuer?
Old Dec 15, 2006 | 01:53 PM
brasso's Avatar
you should be able to twist it with your fingers so you can see A few ribs
but not all of them hope this helps a bit
Old Dec 15, 2006 | 02:14 PM
trialt's Avatar
thx for the info ill check it out
Old Dec 15, 2006 | 03:47 PM
BlackCat's Avatar
RIP '98 Maxima SE
Originally Posted by matty
Blackcat,
-matt
Yep I did. Had to cancel my dynotune appointment due to heavier than usual snow.
AcuraLegend
Oct 17, 2016 08:47 PM
spencerwh1
Jun 30, 2016 05:44 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
0m3nc0w
Sep 11, 2015 05:21 PM
