Adjusting Air/Fuel in closed loop (interesting discovery)
Old Feb 15, 2007 | 09:39 AM
streetzlegend's Avatar
Well after having problems with the car running and leaning out on me, we found out it was a bad o2. Now I have been driving with both bank o2 sensors disconnected. Ofcourse the car runs really rich specially with stock maf and z32 injectors, and the fact that its running of the safe map or w/e. a/f at idle and below 3k (or cloosed loop) is in the 11's.
Now, I have VAFC2. I figured since the o2 sensors are not connected, the ECU is not going to try and fight what ever correction I make in closed loop since it dosnt know where the a/f is at and its running of a predetermined map. So what I did is get into the narrow mapon the vafc2. go to the 1500RPM mark, rev the car in idle to 1500 and remove fuel. When I did this right away I saw the a/f start going up till it passed the 14.7 range, then I made less correction till I got almost near perfect 14.7. Also my throttle %'s are set to 10% and 90%. I started driving observing my a/f. at idle the a/f is now at high 13's(since I didnt have any rpm point below 1500rpm). As soon as you accelerate a/f goes to mid 14's and stays there no matter what throttle position. Basically while driving its at near 14.7 it even fluctuates less than having working o2 and letting ecu make corrections. When RPMs go above 3k ofcourse it goes into the Wide map and thats the normal tuning we always do above 3k. [The correction I made at 1500 rpm is -13.]
The only thing I think might be of some concern is the timing. With o2's disconnected and ECU running of the safe map or w/e it is. Timing gets retarded. Now by making the corrections I did, timing gets advanced back. The thing is, how much does timing get advanced? and is it more advanced than if the ECU was running with o2's?
I think this is a great discovery (i havent read anyone do this before at least) specially for those with large injectors, and SPECIALLY for those with smaller turbos that start to show boost below 3k.
I think depending on the fuel system setup on boosted application, If boost starts coming in at for example 2k or below, that is still in cloosed loop at 14.7 and underboost thats not good at all!!, so now with what i found, i think this can be a great thing that way you can tune for when boost comes in. Thing is, its going to give out o2 codes (Which i dont mind since i permanently have codes, iacv)
Old Feb 15, 2007 | 09:24 PM
Tatanko's Avatar
Bacon Lover
An interesting discovery indeed and not a single reply
Old Feb 15, 2007 | 10:38 PM
nismology's Avatar
Cool beans. Why do you think the timing is getting retarded as a result of the o2's being disconnected though?
Old Feb 16, 2007 | 06:47 AM
Nealoc187's Avatar
SLOW
Where'd you get this info. I've never read that anywhere. I had no working O2 sensors on my old 96 maxima and that car did not show any signs of having timing pulled. It went almost 99mph on the stock ECU with only I/Y/MEVI...
Old Feb 16, 2007 | 06:48 AM
Well I have been asking around because I am not really sure if timing gets retarded when the o2's are bad or unplugged. Perhaps you know?
If timing does not get retarded from disconnecting the plugs, then by me doing the corrections in closed loop I am adding even more timing to the already advanced timing the ECU is doing. I know that at part throttle and below certain RPM maybe 3k (not sure of this) the ECU advances the timing so that there is better response. So maybe its not a good idea that I am advancing it on top of that. I have to get my hands on a logger and check it.
Old Feb 16, 2007 | 02:43 PM
xnyc's Avatar
since you disconnected the o2 sensors, woudlnt that mean that wat your doing now is adjusting openloop fuel trim?
Old Feb 16, 2007 | 03:02 PM
isnt open loop above 3K and above 40% throttle? im adjusting the a/f below 3k
Old Feb 16, 2007 | 04:42 PM
nismology's Avatar
Ahhh...i just thought about it and he's right. When the o2's are disconnected or bad the ECU stays in open loop full-time.
Good catch xnyc.
Old Feb 16, 2007 | 06:02 PM
Tatanko's Avatar
Bacon Lover
So if they're in open loop all the time, that does indeed mean tuning below 3000 is possible without interference from the ECU's pre-set tables?
Old Feb 16, 2007 | 07:16 PM
hmmm thats right. I remembr you telling me that once nismology. and yea. your right Tatanko
Old Feb 17, 2007 | 03:51 PM
xnyc's Avatar
all your doing basically would be adjusting the ecus preset calculations
Old Feb 17, 2007 | 04:45 PM
Tatanko's Avatar
Bacon Lover
I was referring to the fact that in closed loop, the ECU tries to "fight" your adjustments.
Old Feb 17, 2007 | 04:50 PM
nismology's Avatar
Well, in reference to your original question, there are no "preset tables" in closed loop. It's based solely on o2 sensor feedback.
Old Feb 17, 2007 | 05:52 PM
Tatanko's Avatar
Bacon Lover
Really? Hmm...I've read a lot of BS then.
Old Feb 17, 2007 | 07:11 PM
95turbo gxe's Avatar
Thats great. When I had my 3rd gen I had no o2 sensors. ANd it was no problem with airfuel. Well i can check this out with the eu after I unplug them.
Old Feb 17, 2007 | 07:59 PM
Kevlo911's Avatar
Kevlo for President
Why??????? You can tune some in closed loop w/o ecu adjusting back and no cel.
Old Feb 18, 2007 | 06:19 AM
What are you refering as "no problem with a/f", you mean your a/f did not get rich at idle and cruising from havin o2's unplugged?
Kevlo, well you still will get a CEL since they are unplugged. in mycase I dont care because my CEL is always on for other codes i cant do nothing about, so i dont mind it.
Old Feb 18, 2007 | 06:25 AM
Kevlo911's Avatar
Kevlo for President
I gotcha. I tried a lil bit of tuning in closed loop and the ecu did not throw a code or try to go back to 14:7 af.
It would hold steady in the 13's w/o problems. But I have yet to try it long term.
Old Feb 18, 2007 | 07:02 AM
No im sorry im saying that when it was unplugged it would not fight the safc. I did not relize my o2 wire got snagged on something and was not connected. When I repaired it and got it plugged back up it would not let me adjusted anymore but i was not aware that was the problem intill now. Good find.
Old Feb 18, 2007 | 07:13 AM
gtr_rider's Avatar
192.168.1.1
I told you it was a bad O2 from the beginning, wanna buy mine?
Old Feb 18, 2007 | 08:55 PM
meh no need, point of the thread is to delete the o2's.
BTW all, i just went on a trip. 4 hour drive to Tampa. while driving i was monitoring a/f. went the whole way in the mid low 14's. so far no problems or anything. So this is a success.
Old Feb 19, 2007 | 01:14 AM
tavarish's Avatar
fwd gone rwd cr00
Next mod: VAFC, Wideband, and NO O2's.
Old Feb 19, 2007 | 11:14 AM
gtr_rider's Avatar
192.168.1.1
interesting
Old Feb 19, 2007 | 12:56 PM
95BLKMAX's Avatar
just out of curiosity, how many miles did you get on the tanks to and from Tampa? and how do they compare to your previous NA highway tank?
Old Feb 19, 2007 | 01:25 PM
Well, on the way there I was floored it a few times so that might hurt milage, but when i got there, i had a little bit more than 1/4 tank left, and I had done about 290 miles of travel., the same for when i came back.
Old Feb 19, 2007 | 01:49 PM
95BLKMAX's Avatar
oh man, thats perfect! If I made that same trip right now I would probably get there puffing on fumes with my bad o2 sensor. Sounds like the WB o2 closed-loop tuning is in deed a success. Congrats Majan! Amberbach for j00 FTW!
Old Feb 19, 2007 | 02:53 PM
Indeed, you pay.
Old Feb 26, 2007 | 05:37 AM
Chief Brody's Avatar
You could just pull timing with the emanage right? How's the normal drivability/gas milage while in this forced closed loop?
Old Feb 26, 2007 | 05:45 AM
Well I dont have emanage hooked up. but yea you can pull timing with it.. i havent filled up tank and driven in the city till it was empty yet. But i did go on a trip and got good gas mileage. as if the o2's were in good shape. ill fill up the tank and daily drive it around city till its low n see wat kind of mileage i get.
Old Feb 26, 2007 | 06:47 AM
dfownz's Avatar
Can the same be done with a safc, or does only vafc have the capability to do this?
DF
Old Feb 26, 2007 | 01:27 PM
95BLKMAX's Avatar
DF
Either one. I have an SAFC-1 and it has dual maps (Hi map for the normal tunable open loop, and the Lo map, for closed loop). With what streetz is doing you would tune the Lo map of an SAFC for the same result. But again, you need a wideband o2 to do this yourself and properly monitor it during driving.
Old Mar 21, 2007 | 02:28 PM
jmeister's Avatar
Well I tried this today since my car's been running rich in closed loop. With the front O2s unplugged I was not able to make any adjustments to AFR via EU either by injector or airflow adjustment. Actually I didn't see any difference in AFRs with the front O2s connected vs. unplugged.
May try to force open loop with the EU eventually but figured I'd try this due to ease and simplicity.
Old Mar 21, 2007 | 02:44 PM
nismology's Avatar
Try disconnecting the rear o2 as well.
Old Mar 21, 2007 | 02:52 PM
jmeister's Avatar
well the rear is my wideband
Old Mar 21, 2007 | 03:16 PM
thats weird man, try adjusting a/f only with maf signal. the ECU shouldnt be fighting it if it dosnt have signal. I dont see how the ECU is going to not adjust if it dosnt even kno what the a/f is in the 1st place.
Old Mar 21, 2007 | 03:24 PM
nismology's Avatar
Well usually the ECU will try to adjust the a/f back to stoich using the rear o2 if the front o2's aren't sending a proper signal. But he doesn't have the rear o2 connected so it should definitely be in open loop.
And even in closed loop a/f changes are possible at idle with the EU. Hmmm...
Old Mar 21, 2007 | 03:43 PM
jmeister's Avatar
Yeah, I'll mess with it more tomorrow & see what comes up. I only tried the injector adjustment on AFR self tune.
Old Mar 21, 2007 | 04:09 PM
nismology's Avatar
Use the regular injector adjustment map. You should be able adjust the a/f to the point of engine stumbling at idle. A put 1 and then 2 in the very first cell and my friend's car damn near shut off.
Old Mar 21, 2007 | 04:33 PM
Yeah i did mine through the injector adjustment with the eu
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
leatherneck
Sep 30, 2015 09:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
