looking for A place to get a bullet proof 5speed
Does any one know of any good place that I could get my 5speed tranny built? I seen where neal had his done but they did not seem to think to that you would still have to shift to 3rd easy.
you could try something like this http://www.sr20forum.com/showthread.php?t=189124
Looks similar to a maxima tranny inside.
Originally Posted by Alex_V
Why not a 6speed? Should be good for a bit more WHP stock correct?
~Alex
~Alex
Originally Posted by d00df00d
Tranny mount, throwout bearing spacer, and some minor custom work to run shifter cables instead of the rods. That's about it, IIRC....
ok well right now Im working on putting a 03 spec v tranny in my 95. from what I can Tell by some diragrams that they are the same and it will bolt up. ill use a 5.5 gen clutch and flywheel.
Why? The 5.5 gen flywheel is a LOT heavier...
Ah. Good thinking.
If you're looking for something that will hold power, maybe you can use a 350Z clutch? I think SR20DEN knows a thing or two about how to make that work...
MardiGrasMax had one....
Originally Posted by hacim105
Have you thought about heat treating or cryo treating the tranny parts?
That's the only way I could think to makes the parts stronger.
But probably very costly.
litch
123
Jan 4, 2024 07:01 PM
TKHanson
Nov 24, 2018 01:39 AM
