HELP!!!! my s/c maxima is missfiring
Old Mar 6, 2007 | 03:49 PM
dahman45's Avatar
hey i need some help, i went to my car this afternoon and when i strarted it up i noticed that it was missfiring really bad. i was able to drive it home but there was a big power loss. i have a 99 maxima supercharged, cattman headers and catback exhuast and all the stock parts that came with the stillen kit. need help as to what i need to look for!!!
also when i give it gas the exhaust sounds like a WRX, and u can hear it backfiring really bad.....dont know if this helps!!!
thanks!!!!!
Old Mar 6, 2007 | 03:59 PM
matty's Avatar
Any codes ??
99's are notorious for Coil problems but dont jump to conclusions till you run it for any codes.
-matt
Old Mar 6, 2007 | 04:01 PM
PFI30t's Avatar
sounds like a fuel problem. check the codes in the ecu if you can and let us know. do you have a exhaust leak? is your exhaust smoking? could be a leaky fuel injector. i had the same problem and it was an leaky injector and a exhaust leak. my car was just like yours it sounds like a wrx and i lost boost. when i would give it full throttle i would see like 3psi. did you notice any boost lost?
Old Mar 6, 2007 | 04:49 PM
BoostedSileight's Avatar
Sounds like a leaky injector, might want to check that. Check the plugs for fouling, if it's been doing it you'll know.
Old Mar 13, 2007 | 03:16 PM
dfownz's Avatar
You can easily check the coils while the car is on and misfiring by just unplugging them(one at a time to see if it gets worse). Check those out. 2 of mine have gone bad so far.
DF
Old Mar 13, 2007 | 07:40 PM
Nealoc187's Avatar
SLOW
DF
kinda, sometimes. You can have coils that work fine at idle and light load but then misfire when you give it more throttle...
Old Mar 19, 2007 | 01:18 PM
dahman45's Avatar
well i checked my codes and 0304 came up and i changed my knock sensor, still the same problem is happening, does anyone have any clue what this could be, now when i check my codes the only thing that comes up is 0505, which is normal
Old Mar 19, 2007 | 01:53 PM
matty's Avatar
My guess would be a Coil Problem. Knock sensor wont cause missfiring at all
-matt
Old Mar 19, 2007 | 06:34 PM
dahman45's Avatar
is there a way of checking without having to replace them all?
Old Mar 20, 2007 | 07:16 AM
I30tMikeD's Avatar
If you have a rough idle because of a bad coil pack, and you should if indeed one is completely dead. Then disconnect each one and listen for a change in idle quality. When disconnecting one there is no change then that coil pack is bad
Old Mar 20, 2007 | 10:06 AM
dahman45's Avatar
thanks im gonna have to try that
Old Mar 20, 2007 | 05:26 PM
My hunch is coilpacks or sparkplugs. Are you running one step colder plugs? What gap? Mess with your fuel injectors lately? Clogged fuel filter? Failing fuel pump?
Old Mar 21, 2007 | 07:39 AM
dahman45's Avatar
yeah im going to replace my plugs today and see what happens. im running normal plugs, and everything stock or stock from the stillen kit
Old Mar 21, 2007 | 08:28 AM
dfownz's Avatar
I believe if you bring your car to autozone they can test the coils. I used to work there and tested them myself via the testing books they should have.
Not sure if they'll even know what you're talking about though. Give it a try though (they'll do it for free if they are able to).
DF
Old Mar 21, 2007 | 08:38 AM
When I had coilpack issues, I found that testing them was inconclusive. I tried what the FSM recommends, Haynes, and Chiltons. 3 different methods, 3 different results. Very misleading results. They appeared to be fine for the most part. I swapped coils with Ptatohed for a day and determined that I had full power with his coils. I bought new coils and my car has been good ever since.
Old Mar 21, 2007 | 10:13 AM
dahman45's Avatar
when u check each coil pack by disconnecting them do u leave the car running and unplug one at a time or do u turn it off and switch back and forth?
Old Mar 21, 2007 | 02:39 PM
dahman45's Avatar
fixed was a bad coil....thanks for all the help!
halfpol
Oct 17, 2022 12:16 PM
Goffery2uned
Aug 21, 2015 09:50 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
