???? solder not sticking!!!!!!!
Old Mar 13, 2007 | 02:47 PM
dfownz's Avatar
Hey guys,
I'm trying to solder back together my rear harness for my o2 sensor (fed spec). I just ran over to RadioShack and bought a 25-watt solering iron and some rosin-core solder. Thing is it won't stick to the wires. I can't tin them or anything, it just runs right off. This is with the wire heated up too.
I thought I was good at solering too!
DF
Old Mar 13, 2007 | 03:13 PM
dfownz's Avatar
If you can help, please chime in! I have the opportunity to do it right now.
DF
Old Mar 13, 2007 | 03:50 PM
eng92's Avatar
Surface contamination and not enough heat are the two main reasons for solder not sticking.
The high temperature rated wire used for o2 sensors is a bit more difficult to solder well. Most people end up using crimp type connectors.
When I extended my primaries for my header install, I used silver solder and a micro-butane torch.
Old Mar 13, 2007 | 05:20 PM
dfownz's Avatar
Good looks man. I was wondering what was going on. I really heated them up too but it just kept beading off.
I'll have to run to Radio Shack and grab some silver ish.
DF
Old Mar 14, 2007 | 12:19 PM
Matt93SE's Avatar
STFU n00b!
O2 sensors use stainless wire, IIRC. either that or they have some other bright silver plating on them that makes solder a PITA to stick to it.
try using acid core solder (you may not be able to find it anymore), or in worst case, use crimp-type butt splices and then seal them with a blob of RTV and electrical tape over it. (we build splices like that for offshore all the time and I have yet to have one fail on me)...
Old Mar 15, 2007 | 10:07 AM
dfownz's Avatar
Yeah I used rosin-core and silver bearing soler. Neither sticked even under a torch. I didn't get them WICKED hot because I was holding the wire, but I couldn't seem to do it.
Butt connectors ftw!
DF
Old Mar 29, 2007 | 08:49 AM
MOHFpro90's Avatar
Hey, get some solder flux. Works GREAT for soldering wires...trust me.
AaronL
Nov 15, 2020 11:52 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
dcardello
Sep 3, 2015 11:44 PM
