need some fp advice now...
Old Mar 16, 2007 | 05:28 AM
trialt's Avatar
ok.. so i hooked my fmu back up and i figured out how to reduce belt slippage.. so now im getting 14-15psi... my 370cc's and sard fpr are on their way and I was wondering what fuel pressure i should adjust it to at idle? also as for the fmu do I have to change anything on it? thx in advance.
Old Mar 16, 2007 | 07:52 AM
BlackCat's Avatar
RIP '98 Maxima SE
I've read that the base should be at 34 psi
Old Mar 16, 2007 | 09:30 AM
I believe BlackCat is correct. My Fuel Pressure gauge does read 34psi at startup/idle.
What size disc do you currently have in the FMU??
Old Mar 20, 2007 | 10:39 PM
UNDEFINED76's Avatar
do u have a intank fuel pump??
Old Mar 21, 2007 | 10:36 AM
GodFather's Avatar
Made in Taiwan
Kinda OT, but for only 7psi's on 3.6" pulley, what size disc should we install? Heard 8:1 is stock from the V2 kit, but tune's a bit rich.
Conceptually, I thought the larger the disc size, more fuel pressure is produced by the fmu on boost, then afr would get richer. Am I right? If so, then for my intended 7psi, can I safely use a 6:1 disc? Thanks.
-Peter-
Mahmuth
Aug 16, 2024 08:23 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
dshinn
Sep 26, 2015 08:07 PM
