Lost power and Backfireing??
Old Mar 20, 2007 | 10:45 AM
Stillen Maxima's Avatar
Pay to Play
Today being such a nice day out, i decide to drive my max. I get on the beltway, i havent felt boost for 830miles and am so wanting to feel what this clutchnet can do so. Im on 3rd gear and push it. As the rpms get higher and higher i notice that the car is taking a little long to reach boost. It got to 5psi and felt that the car was struggling to go higher. Hmm this has never happend to me before. I try to punch it again and the car just feels not normal. I pull over and my vac is at 20 my gauges are all fine. I pop the hood and everything looks fine. I get back on the beltway and i can feel my car loosing power slowly. Im cruising on a little hill at 60mph and felt this small little jerk and see my rpm is going down. I slow down and push it for the third time and the car doesnt respond like it did when i had my old motor. Im getting to work and as im changing gears my car is backfireing....POP like if has firecrackers up the ***. I get to work the car sounds normal and what i did notice is that when i rev the engine the rpms drop to about 400rpms and it goes right up but it feels like its gonna shut.
I Know this is kinda long but bare with me here. Im at work and dont have access to a scanner. What can be causing this? Any idea would be very
helpfull.
-Albert-
Old Mar 20, 2007 | 12:54 PM
trialt's Avatar
sounds like a bad maf, or o2 sensor... same thing happened to me... new maf fixed it.
Old Mar 20, 2007 | 01:09 PM
Pay to Play
Yea i thought of that. Im gonna get my codes read today and take it from there!
Old Mar 20, 2007 | 05:25 PM
Check your spark plugs too. Are you running one step colder? What gap? Tinkering with your fuel injectors at all? How's your fuel filter? Maybe a failing fuel pump too.
Old Mar 21, 2007 | 08:08 AM
Pay to Play
Last night after work I went to get the codes and i got the following....
P0325
P0136
P1605
P1400
P1220
WFT?? Too many!
Old Mar 21, 2007 | 09:52 AM
cardana24's Avatar
Blown
P0325 Knock Sensor
P0136 Down Stream O2 sensor Fault
P1605 A/T control Fault
P1400 EGR selenoid/valve circulation fault
P1220 Fuel pump control module fault
WFT?? Too many!
Albert, ^^^ this is what the haynes manual says the faults are. I don't know what an A/T control fault is. If this was happeing to me I would say with your symptoms I would try to figure out P1220, the fuel pump control module first.
Old Mar 21, 2007 | 10:34 AM
Pay to Play
Damn, that little brown thing is a pain to get to! Is this what's causing my car to loose power? Remember we took a peak at it before we put the motor back and it looked ok?
Old Mar 21, 2007 | 11:00 AM
cardana24's Avatar
Blown
I don't remember that I don't even know where it is.
Old Mar 22, 2007 | 01:40 PM
Pay to Play
Can anyone give me a clue on what to check with this code-P1220 Fuel pump control module fault
A friend of mine and I have been trying to figure out what this could be? Has anyone ever had this?
Old Mar 27, 2007 | 04:35 PM
Pay to Play
Problem solved! Thanks for the help to those who did and thanks for reading to those who didnt. My car feels faster than a like a cheetah on Cokaine!!
Old Mar 27, 2007 | 04:55 PM
So, what was the problem?? Fuel pump??
Old Mar 27, 2007 | 08:30 PM
Pay to Play
Hose was cut and was loosing vac to the intake mani! Replaced the Knock sensor while at it.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
