Turbo Specialties VQ30 turbo kit review
Old Oct 11, 2007 | 10:26 AM
  #201
AceofSpds's Avatar
wat
Originally Posted by bohead
Hi Doc,
Can you confirm if the turbo is fed by both manifolds? The pic on turbospecialties seems pretty misleading. Do you have any closeup pics of how the rear manifold feeds the turbo?
Thanks,
Dude, freakin read the thread, this question has been asked several times on several pages.
Old Oct 11, 2007 | 02:40 PM
  #202
doc2278's Avatar
Doctor D I presume???
Hi Doc,
Thanks,
i can indeed confirm it because I installed the manifold piping. This feeds from the rear header to the turbo from the underside of the cast manifold. Quite well done if I say so.
unfortunately I would have to get a lift to be able to photograph the piping.
I have been bound by agreement not to release the kits' instructions to any other party (just like if you were to copy a book and distribute it over teh intranets), BUT i will tell you it has a pic of it clearly showing how it is set up.
Old Oct 19, 2007 | 01:34 PM
  #203
KRRZ350's Avatar
Originally Posted by My sexy ****, in an E-mail to turbo specialties
To whom it may concern,
My name is Kevin Goodwin and I run a small garage in middleboro, ma, where I primarily deal with nissan maximas and get the majority of my clientel from a website called Maxima.org. I have a customer who already has a turboed maxima w/3.5l engine swap and he also wants to turbo his daily driver when I replace his engine shortly, and he asked me my opinion on this kit. Before I even did any research on maxima.org or noticed on your site that it was initially designed for the VQ20 Cefiro, I saw T28 and sorta laughed. I told him that was junk, way to small for any 3.0L V6 nevermind one with such an amazing volumetric efficiency in its N/A form. However, he mentioned that you guys had adaptor flanges available for a T3. After Doing some research on Maxima.org I soon learned that even if you guys don't have adaptor flanges, they are available elsewhere.
So, I was wondering what else you guys would be able to supply for a turbo with this kit, I'm thinking something in the range of a .60 a/r on the compressor side and .5x on the exhaust turbine. Also, do you have any more information about your 2 additional injectors, how they are controlled relative to boost etc, and would it be possible to get the kit for slightly less, or offset the additional cost of a different turbo by getiing it without any fuel upgrades. Also, If you could please supply a compressor map of whatever turbo you guys could substitute that would be awesome, allthough I'm sure I could find it if it's to much of a hassle.
At the bottom I have provided a link to the thread on Maxima.org about your turbo kit. I think you will find it very beneficial to register on the site and participate in the thread. This way other members can speak directly to you and ask questions, it will also help you figure out exactly what the majority of them are looking for, and in the end will allow you to put togethor a much nicer package that will sell much better, in addition to building a raport and reputation with your customers. Please help us maxima guys out! We need something now that the PFI kit is no longer in production http://forums.maxima.org/showthread.php?t=391713
Sincerely,
Kevin Goodwin
Hopefully I'll at least hear a response back, lol, and maybe he'll get the ball rolling and there will be good things to come, the price of the current kit is pretty much stellar, and I'm sure many would have no qualms about paying a little extra for something that could actually do something other than make cool sounds, lolz. Also, what's the general consensus about the piping diamater currently provided?
Old Oct 19, 2007 | 04:32 PM
  #204
t6378tp's Avatar
Turbo 3.5
too small
Old Oct 23, 2007 | 11:01 AM
  #205
doc2278's Avatar
Call them up. You get better results,... or ask them to give you the number to their Conneticut branch.....ftw
Old Oct 24, 2007 | 06:53 PM
  #206
maximabebe's Avatar
Ct branch??? I didn't see anything about that on their website. I may get me a kit minus shipping costs.
Old Oct 26, 2007 | 06:12 PM
  #207
doc2278's Avatar
gotta call doug Adams at turbospecialties to get that #. Their main # is on the website..
Old Oct 27, 2007 | 09:48 AM
  #208
maximabebe's Avatar
thank you doc
Old Oct 27, 2007 | 12:11 PM
  #209
00SEMAX19's Avatar
Been following the project for a while now so I'll subscribe.
Doc, Any updates on the bigger turbo? Did you get it installed/dyno'd
Blackbird, Any progress for you yet?
I am also interested in the kit. I think a 3.0 kit would easily be modified to fit the 3.5 So this would deffinately be an easier starting point than going custom.
Old Oct 27, 2007 | 07:16 PM
  #210
doc2278's Avatar
Based upon what I have seen,this kit with some minor modification will fit a 3.5
the very good news;
your 3.5 is the same block as the 3.0 just with different parts (to simplify) so fitment would be identical to mine.
- trouble areas you might run into;
intercooler piping- different front clip might mean shortening/ lengthening i/c piping.
-finding the rpm signal wire on your ecu and mating it to the injector control module.
- ohh my...... where will I place my boost gauge???
- intake piping into the turbo, room constraints are slightly different on a 3.5.
-the space between the radiator (if upgrading the turbo) may be very tight depending upon what turbo you choose. what will not be so much of the issue will be the exhaust turbine housing,.. I figure you can put in a t3/t4w/o many issues. ******* worst case scenario,.... buy a set of thinner fans. there is at least an inch or two of play between the radiator fan and the compressor housing with stock fans. YOU MUST BUY THE NEW FRONT MOTOR MOUNT (incl. in the kit) REGARDLESS!!!!!! stock will not work at all.
In doing this kit, this is what I have evaluated as "maybe" areas of concern when doing this kit on a 3.5.
word to the wise: if you build it,.....they will come.
Although I am shopping for a bigger turbo, I have not determined which direction I would like to go as of yet.
I am however curious as to Blackbird's progress on his turbo endeavor
Old Oct 27, 2007 | 07:23 PM
  #211
doc2278's Avatar
thank you doc
no problem at all
Old Oct 27, 2007 | 07:25 PM
  #212
doc2278's Avatar
shipping to NJ was only 50.00 (not bad IYAM). either way you want to work it
IYAM= if you ask me
Old Oct 29, 2007 | 07:21 PM
  #213
babymac's Avatar
BOOST 4 LIFE!
Chris grab yourself a t3/4 and just change the flange on the manifold and you'll be good to go..maybe a minor mod here or there on the intercooler piping. The 2inch piping will be fine till around 280-300whp, so get it tunned to run about 275-290whp and then you'll have a nice kit. And if you want more power then just change the intercooler piping to 2.5 and then the sky's the limit....(tranny)
Old Oct 30, 2007 | 07:40 AM
  #214
maximabebe's Avatar
Quick question Doc....What is the diameter of the scavenge pipe from the rear bank to the hot side of the turbo?
Old Oct 30, 2007 | 08:00 AM
  #215
doc2278's Avatar
2 1/4 inch
Old Oct 30, 2007 | 07:22 PM
  #216
maximabebe's Avatar
Nice. I feel better now.
Old Nov 6, 2007 | 08:57 AM
  #217
nismomaxct's Avatar
Is there any way that this kit would be able to run a T4 turbo?
Old Nov 6, 2007 | 09:08 AM
  #218
maximabebe's Avatar
I would be inclined to say yes if you contact the Ebay seller that Kevlo mentioned on the bottom of page 4 of this thread. Apparently he can make the T-25 manifold plate that adapts to various sized turbochargers on the other side. It is because of that machined adapter that is keeping me interested in this kit.
Old Nov 6, 2007 | 10:18 AM
  #219
kzoosho's Avatar
Ok i posted the link to them in my post also and i have purchased a flnage from them. They are good quality and can make any flange you want.
Old Nov 6, 2007 | 10:28 AM
  #220
nismomaxct's Avatar
Im sorry, I should have phrased my question better. I meant to ask if doc thought there was enough room to mount a T4 turbo there, say a GT35 for example?
Old Nov 8, 2007 | 08:25 PM
  #221
t6378tp's Avatar
Turbo 3.5
Originally Posted by BlackBIRDVQ
I just placed my order for some of this kits parts.....
My turbo of choice : GT3071R T2 flange 50 a/r comp56 trim .86a/r 90trim turbine w/internal WG and 7psi spring.
I'm looking for response and around 320WHP for my daily duties.
hey did you get your parts yet and if so did you have a chance to test fit anything
Old Nov 9, 2007 | 10:45 AM
  #222
MaxBoost925's Avatar
Drug Money
I think you should upgrade to a T3/T4 like everyone suggesting Doc. It'll help you put down better numbers.
Old Nov 10, 2007 | 09:06 AM
  #223
doc2278's Avatar
there is, clock the compressor side it should fit, exahaust side you have alot of room ( enough for a gt35r),.... here's the possible catch,... You may have to change out your radiator and fan set ( along with the coolant piping) which is not hard. some orgers have done it. t3/t4 should not be a problem. even a gt2871rs will fit with little or no changes needed.
Old Nov 10, 2007 | 09:16 AM
  #224
doc2278's Avatar
I agree with you maxboost 100%. Only trouble I am anticipating running into is since I am automajic i will need to do a tranny swap for sure ( cause we all know that once you go boost,... you want more power )
I am hesitant only that the price for a t3/ t4 new is a bit higher than I would like. I can flip my t-28 for around 650.00 I have to come up with another 500-700 bucks- not to mention a re-tune (another 120.00 which is not bad)( I only pay cash for my mods No matter what it is- dont want any outstanding bills) UNLESS ANY OF YOU CAN FIND A T3/T4 FOR CHEAP (cause I cant seem to find them in my price range).....hint, hint.
Old Nov 10, 2007 | 01:52 PM
  #225
Drug Money
Homie I bought my T3/T4 hybrid for $450 with a wastegate.
They're both genuine parts too, no fake stuff. Use teh search ftw! I searched for a solid week to find this deal!
Old Nov 13, 2007 | 03:15 PM
  #226
shiftnatredline's Avatar
Godzilla
Originally Posted by kzoosho
Thats the guy i got my flange from. very fast shipping and great flange.
except they haven't sold anything since september....
Old Nov 13, 2007 | 04:15 PM
  #227
kzoosho's Avatar
maybe noton ebay bt the do have a business and there flanges are real nice.
Old Nov 13, 2007 | 04:23 PM
  #228
Godzilla
http://cgi.ebay.com/ebaymotors/SPA-7...spagenameZWD1V
might be worth looking at
Old Nov 13, 2007 | 05:20 PM
  #229
cld12pk2go's Avatar
Stupid Question: So if a properly sized turbo would have fit in the kit turbo's normal location, why the hell did they put a peanut sized turbo in the normal kit instead of a reasonably sized one?
Old Nov 13, 2007 | 05:42 PM
  #230
MrDicks95SE's Avatar
Offset Is Everything.
its to cut down the price
its like how nissan cheaped out on the interior but have a great engine.
Old Nov 14, 2007 | 12:33 PM
  #231
nismomaxct's Avatar
If you were to upgrade to a t3/t4 turbo, where would you locate the wastegate?
Old Nov 14, 2007 | 01:05 PM
  #232
kzoosho's Avatar
You can always run a t3/t4 with an internal wastegate then there ya go.
Old Nov 14, 2007 | 01:10 PM
  #233
Drug Money
Internal gate FTMFL!
  #234
Drug Money
Anywhere close to the turbo on your turbo manifold.
Old Nov 14, 2007 | 01:29 PM
  #235
kzoosho's Avatar
Please tell me whats wrong with an internal wastegate?
Old Nov 14, 2007 | 01:46 PM
  #236
Drug Money
If you had a choice what would you honestly choose?
I can see many benefits of an external gate over internal - one of which is very important is adjustability as well as boost tolerance.
Old Nov 14, 2007 | 02:12 PM
  #237
kzoosho's Avatar
I would use and internal. They are just as adjustable as external. and just as reliable. ALso if doing a custom job leaves for less pipe work also. If you look docs setup is an internal wastegate. My old dsm runnig 22psi was internal. Yea extenal looks cool but i would much rather have an internal.
Old Nov 14, 2007 | 02:23 PM
  #238
Godzilla
So I emailed turbos pecialties and they said they would send this turbo: http://www.turbobygarrett.com/turbob...R_743347_2.htm
instead of: http://www.turbobygarrett.com/turbob...S_739548_1.htm
Well idk if thats the actual turbo but it says in the first links discription its the direct upgrade for the second link.
Any one think that would be an acceptable turbo for this kit for our engine?
Old Nov 14, 2007 | 02:35 PM
  #239
Drug Money
The second one has a larger compressor.
I'd still say run a T3/T4 hybrid.
Old Nov 14, 2007 | 06:34 PM
  #240
Nealoc187's Avatar
SLOW
the 2871R that he listed first has a much larger compressor than the 2860RS that he listed second does...
you can make up to about 400whp on a 2871R. whether or not the piping on this kit is able to support that much flow is another topic entirely - I highly doubt it is - but that 2871r is a much better fit than that mini turbo the kit normally comes with.
