Misfire/Hesitation in 3rd gear at higher boost
Originally Posted by TurboS13Hatch
Honestly.. I don't usually mess around with factory engine management when I build something that's making big power. I opt for Electromotive's TEC3-R, which comes with GM coil packs. So, I don't really have a lot of experience with rigging up voltage amplifiers on stock coil packs. On a 250-350whp car, we might stick with a stock ECU/piggyback, in which case, reasonable plug gap is possible without a failed spark event, but, above that, I push for my customers to go standalone. With the TEC3, I've run as much as .036-.037" plug gap, on a cold plug, at the 600-700whp level.
Sounds like a good buy for 50 bucks though..
D*ymn, I'd like to see your shop. You're right, of course. When you're building monsters, you don't want weak-sauce sparks. For us normal folk dealing with stock ECUs/coils and needing more sparks, the $50 special works pretty well.
GM coil paks. There's 50-70 Kilovolts at the gap, I bet. Thanks for the view into what your shop creates.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
