is my 520whp a reality ? hope so we'll see with these upgrades
Old Jun 9, 2007 | 07:38 PM
  #41
Tatanko's Avatar
Bacon Lover
Glad to see some useful information being spread around in this thread, even if the OP is never probably going for his stated goal...
Old Jun 9, 2007 | 07:57 PM
  #42
chris'smax's Avatar
Originally Posted by VIP Maxima
3.125 with auto and 100nx wouldnt even give u 300 to the wheels
Its not totally out of the question. I had 299 to the wheels with my auto running the 2.87 running only 10 psi. At the time i was running water meth injection and didn't adjust the tune for it therefore making the tune a little to conservative. There was more in it. Then the motor blew due to oil starvation
Old Jun 9, 2007 | 09:37 PM
  #43
520whpNashville's Avatar
i appreciate the knowledgable advice and the sinical jokes maybe the osterich wont help after all. to answer your questions YES this car/project exist im 95 percent done. its T trim stock compressor wheel its a 3.0 and im open to a turbo & 3.5 setup if not pleased with this setup there closely related in needed parts so itll only need a few swapped parts as for now i still need to get my ecu returned (flashed from jwt for a s/c 9:1 555 setup) and waiting for my converter from dayco to return most of the work wasnt done by me. the numbers are obviously high but it was just a screenname, although it did help motivate me for big numbers it should be ready for break in miles late july. ill definately post results under this name to relate back to this post. im hoping to have it running for the july nashville meet ....... still shooting for big numbers !
Old Jun 9, 2007 | 11:10 PM
  #44
SR20DEN's Avatar
VQ Wizard
Well good luck with your project. But honestly if you put that much money and effort into a VQ30, you've wasted most of it. You can make more power from a VQ35 while spending less money because of it's after market support.
Old Jun 10, 2007 | 07:32 AM
  #45
Tatanko's Avatar
Bacon Lover
T-trim isn't stock, we've been over this.
Also, why do you insist on going with JWT? It's been proven time and again that eManage will kick the crap out of JWT's ECUs, and for the same money even.
Old Jun 10, 2007 | 10:16 AM
  #46
liqidvenom's Avatar
brotherhood of tq
Originally Posted by nismology
IIRC, compressor surge. Motor isn't swallowing enough air up there. Perhaps if some people got cams and headwork the boost limit could go up.
do you think that is mostly due to the im not flowing enough air? i will take some time and look into this though, because i would assume that most turbo guys are flowing it not the same or much more volume of air at less psi.
Old Jun 10, 2007 | 11:55 AM
  #47
PFI30t's Avatar
Originally Posted by wunfstmax
You sure about that...
yes i am sure. i tryed to get that program and they told me that they dont have a 740cc injector and z32 maf program for the maxima. with my setup i will only be able to see 520hp to the flywheel thats with 555cc injectors and a z32 maf. thats what jwt told me.
Old Jun 10, 2007 | 02:38 PM
  #48
wunfstmax's Avatar
Hmm, maybe mardigras was the only one able to get it. I brought his ecu, so I thought that others would be able to get them as well (Its the 740cc with z32 maf)
Old Jun 10, 2007 | 03:45 PM
  #49
PFI30t's Avatar
when i talked to a tech at jwt he told me that there is no program for 740cc with z32 and he also told me that he might be able to do a 740cc with a ford lightning maf but i didnt like that idea. if that ecu that you have is programed for that i will give them a call tommorow and ask them why they told me that and i will let you know what they said.
Old Jun 10, 2007 | 08:06 PM
  #50
NCSU_MAX's Avatar
Maximoneypit
Jeff I sold you an S trim V1....... did you get rid of it for a T trim??
Old Jun 12, 2007 | 05:12 AM
  #51
Blu's Avatar
Blu
the tits
you will not be happy with it for the money you spent.
Old Jun 13, 2007 | 07:45 PM
  #52
chris'smax's Avatar
+1.
That car will only be fun in a straight line (if that)
Old Jun 13, 2007 | 09:44 PM
  #53
EnervinE's Avatar
i has college
If what he says is true, then I own signal lights that were once on a 520 WHP Maxima. No wonder my car feels faster...
Old Jun 14, 2007 | 08:28 AM
  #54
maxgtr2000's Avatar
KH3 by popular demand
Good luck with that goal Cashville, but you will have to do better than this guy..
http://forums.maxima.org/showthread.php?t=504238
3.0 no go, 3.5 yes.
Old Jun 15, 2007 | 06:36 PM
  #55
Sprint's Avatar
Originally Posted by liqidvenom
i can find kits online for other vortech blowers but not for a v2....maybe it was a custom job that i saw
you need a new avatar?
Old Jun 15, 2007 | 06:43 PM
  #56
Sprint's Avatar
EManage is garbage.. there is a reason they call it E-Garbage
Old Jun 15, 2007 | 06:59 PM
  #57
Tatanko's Avatar
Bacon Lover
Uh, what?
Old Jun 15, 2007 | 07:17 PM
  #58
Sprint's Avatar
Uh, what?
uh .. yeah.. had it in my car for 1 month.. got rid of it as fast as possible
Old Jun 15, 2007 | 07:20 PM
  #59
Tatanko's Avatar
Bacon Lover
Well, most of the Advanced forum is going to disagree with your personal opinions. Many here have had success with it.
Old Jun 15, 2007 | 09:10 PM
  #60
Sprint's Avatar
there is better out there.. if i known everyone loved it so much.. i would have sold mine here instead of giving it away for free
Old Jun 15, 2007 | 09:23 PM
  #61
SR20DEN's Avatar
VQ Wizard
<--- Happy E-Garbage user.
Old Jun 15, 2007 | 09:45 PM
  #62
Tatanko's Avatar
Bacon Lover
I would be too if I was given it for free
Old Jun 16, 2007 | 05:36 AM
  #63
Sprint's Avatar
good its blown quite a few Z motors
Old Jun 16, 2007 | 06:22 AM
  #64
SR20DEN's Avatar
VQ Wizard
It's better for NA applications. And it was it always at fault? Or was it the fault of the tuner or end user?
Old Jun 16, 2007 | 08:22 AM
  #65
Kevlo911's Avatar
Kevlo for President
Not being able to use it FTL...
But I can see how it causes problems but once you figure it out(or get it right the first time ) it is just fine. If I had a Z I wouldn't run emanage anyways because of all the other options out there for um
Old Jun 16, 2007 | 08:39 AM
  #66
nismology's Avatar
The Z guys don't really have that many more piggyback options than we do. It's mainly the UTEC being used with the EU a distant 2nd. The hardcore boost guys go straight to standalone's like the FCON V-PRO.
Old Jun 16, 2007 | 08:41 AM
  #67
Sprint's Avatar
yeah it was always at fault.. it was always pulling too much timing.. thats why Greddy TT Kit was always known as unsafe.. then people starting using UTEC's .. ask Don (Pearl96max) he is running my old UTEC
Old Jun 16, 2007 | 08:42 AM
  #68
Sprint's Avatar
i just got the HKS FCon Vpro .. the car should be tuned with it in 2 weeks or so
Old Jun 16, 2007 | 08:51 AM
  #69
Street Reeper's Avatar
Handsome
Why would you spend all that money and get a mail order tune (if I'm reading that right?) Find someone who will put your car up on the rollers and build you a tune.
I love my SCT
Old Jun 16, 2007 | 09:05 AM
  #70
liqidvenom's Avatar
brotherhood of tq
yeah i might...take some new pics and let me pick from those
Old Jun 16, 2007 | 09:24 AM
  #71
Sprint's Avatar
i already did
Old Jun 16, 2007 | 09:25 AM
  #72
Sprint's Avatar
me? .........
Old Jun 16, 2007 | 09:33 AM
  #73
Handsome
me? .........
No, original poster.
Old Jun 16, 2007 | 01:48 PM
  #74
liqidvenom's Avatar
brotherhood of tq
i already did
its a nice shot but.....im not liking the angle enough...people need to know i copied to pic of someone that is boosted..
Old Jun 16, 2007 | 05:28 PM
  #75
SPiG's Avatar
SomePsychoGuy
With the "stupid" A32 and A33 ECUs E-manage Ultimate does everything you would ever need it to. With an ECU that is less tolerant to piggybacks like the Z33 ECU, it is probably not the best choice, especially with plug and play options like UTEC.
Old Jun 17, 2007 | 08:19 AM
  #76
Sprint's Avatar
again... i already did
http://gallery.maxima.org/v/admin/350z
Old Jun 17, 2007 | 08:21 AM
  #77
Sprint's Avatar
Emanage ultimate? those arn't that bad... its the Emanage Blue that blows the motors.. EU is good.. couple people use it.. not as many features as the UTEC or VPro though
Old Jun 17, 2007 | 09:02 AM
  #78
Nealoc187's Avatar
SLOW
it's got features that the UTEC doesn't and he UTEC has features that the EU doesn't.
As far as the EB blowing motors... that of course wouldn't have anything to do with the fact that it is what came with the greddy kit when they first came out and all these retards were trying to crank up the boost without pulling any timing, would it? The EB is not the best engine management out there by a long shot, but it isn't responsible for blowing more motors than bad tuning and bad usage are. that's complete bull. the fact that the Z33 ECU is far more advanced and runs a ton of different timing schemes under various conditions makes the EB not a good idea for that application but it works just fine for other applications that do not have such complicated timing schemes. the EB didn't blow those guys' motors, their lack of knowledge as to what parts to put on their car and lack of appropriate tuning ability is what blew their motors.
Old Jun 17, 2007 | 06:02 PM
  #79
liqidvenom's Avatar
brotherhood of tq
ill fix it asap..i gots to keep up with the dougs
Old Jun 17, 2007 | 06:33 PM
  #80
Sprint's Avatar
the EB was blowing motors on stock boost.. when i ran the EB i was running 4.5 PSI and it still managed to blow all the coolant out of my engine on my hood.. so it has nothing to do with cranking up the boost
MRC gave my car a perfect tune with the EB and it still had an issue.. so i guess you could tell Julian that he is a sh!tty tuner
