more troubles after the 555 install and z32
Originally Posted by 95turbo gxe
11.5 at about 7psi and they were at 96-100% duty cylcle they were 290cc from the dek
That's almost exactly what I was running....
Could this be cuz I'm running crazy rich? Should I take away a lil more fuel? How much did your AF go up after the injector install? I got a MAF...gonna see if thats the prob today. I'll report back
wait? what are you guys new air fuel with the larger injectors? very rich conditions WILL cause alot of misfires/hesitation. iv experienced this, at low 10's or high 9's my car hesitates. 95turbogxe, i cant really see on ur log, but what is ur a/f at when this **** happens?
ok I pulled my codes today. I got p130 with is from the eu I always have got that since I install it but it never gave any driving problems.
But I also have p135 with is the cps code. I never had this before but im wonding Why I have this code I though if the cps did not work the car would not run.
Originally Posted by mtcookson
Have you adjusted that at all? That could very well be the problem... I think we're getting closer now finally!
ok guys after driving today Im really guessing its some type of mis fire because when this happens I smell gas inside the car! I have a open down pipe so I guess that why I smell it.
Originally Posted by tsaulz
Do you mean p335, because p135 is for the o2 sensor? If it is p135, could the car be going into limp mode, causing your problems?
Ok last night I tested the cps in stead of getting 5v at the white wire I was getting like anywhere from 1.4v to 0.70v when I took a screw driver and touch the end of it and pulled away quickly. Now with the sensor un plug the harnes is sending 5v on the white wire from the ecu. So I went to the junk yard and got a another one and put in and clear the ecu with scanner tool. Went for a drive and it move the break up point from 3800 to now happening at 4500-4700. Wtf
I would double check the timing both with the CPS and in the Emanage... that's the only thing I can think of at the moment.
yeah mark I put a new sensor on and it change to 4500 Im thinking mu cps ring is not right when i welded it to the flywheel
I mean is it possible that it can shift??? My car ran fine NA...and boosted....the problem came after the bigger injectors...
I changed the MAF...still same thing. I'm gonna mess with my fuel setup, try removing the FMU and see what happens. I'm thinking the walbro and 440's are making it run crazy rich when the FMU kicks in. Like I said, in a week I'll have the WB and will have a much better idea whats going on.
yeah I would not even go wide open throttle with my car with larger injectors with out a wideband.
Also Im have a 6speed tranny that I had to weld one on It may not be even or in the right positive Tilley said he had the same problem one time too.
95turbo gxe, your wideband is measureing all the cylinders at once, you could have lean or rich cylinders that average out to 11.x. Could be a EU thing under a specific load condition, and 6th grear will see higher loads and therefore not buck. Just a thought.
bryants95max
Oct 2, 2015 12:52 PM
markevans999
Sep 10, 2015 04:29 PM
