3 Bar MAP volt ---> boost conversion, anyone?
Old Jul 12, 2007 | 11:16 PM
streetzlegend's Avatar
Well i just got me a 3bar GM map sensor. Its hooked up already, did a few runs and logged it. So far all i know is that 2.5volt is about 10psi, but I would like to know if anyone knows the exact conversion from volt to boost for 3bar map sensor? I also noticed at idle with 0% throttle, the map volt is 0.77v-0.79v
Old Jul 12, 2007 | 11:24 PM
Nealoc187's Avatar
SLOW
Google son, first link.
Old Jul 12, 2007 | 11:30 PM
hmm. dosnt seem right to me though. at 10psi mine reads 2.54v and in 20vacum its about .77v
Old Jul 13, 2007 | 05:45 AM
95BLKMAX's Avatar
Mad tyte JDM Voltage???? lol. I'd assume the EB has some sort of setting to know what MAP sensor it has, you sure thats correct? Assuming that the graph Neal posted is correct, your "line" is alot steeper than the 3Bar line on the graph there.
Old Jul 13, 2007 | 05:47 AM
Yes im sure its correct. I dont know if the EB has some parameter changes i can do for it.
Old Jul 15, 2007 | 08:04 AM
Ok, so I got question solved. Now I have a new question. Is there any way possible I can log boost and wideband with emanage blue. It only has one port for either boost or wideband. So any rig i can do to be able to put both?
Old Jul 15, 2007 | 10:45 AM
95turbo gxe's Avatar
Hey can you use the reltive pressure chart. My eu has that and it will convert it for you into psi
Old Jul 16, 2007 | 07:26 AM
maxine'sMan's Avatar
what was the answer?
Old Jul 16, 2007 | 08:32 AM
Well, the person that sold me the map sensor sent me an excel document that converts pressure into kpa, and then into voltage, etc...
Old Jul 16, 2007 | 08:50 AM
Nealoc187's Avatar
SLOW
Why don't you post it if it's different than the one above so we can see the difference?
Old Jul 16, 2007 | 08:59 AM
Here you go. i just made this to compare the two.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Calabar
Oct 5, 2015 09:57 PM
MichMaxFan
Sep 30, 2015 09:18 AM
