Some More Questions for ClutchNet Owners
Old Jul 13, 2007 | 03:34 PM
matty's Avatar
Alright, 6 puck sprung hub//Fidanza Flywheel. Everytime I start the car when its cold, I get a horrific grideing sound when the clutch comes together with the flywheel. Right when they meet, it grindes. ONLY when the cars cold though and only the first 4 or 5 clutch releases in first. It only really does it when Im at a stop, when im rolling and going to a gear, theres no grindeing..
I just wanna know if you guys running this clutch get this sound like me ?
-matt
Old Jul 13, 2007 | 04:01 PM
Nealoc187's Avatar
SLOW
I've occasionally had a moaning type of noise when bringing the pedal up but it's nothing that's consistent, I only remember hearing it a few times.
Old Jul 13, 2007 | 04:26 PM
Stillen Maxima's Avatar
Pay to Play
Not one sound over here other than the usual chatter on 1st gear if i dont rev the rmp's a little high and maybe a little chatter on 2nd gear....But very little. Other than that no sound like the one you get.
Old Jul 13, 2007 | 04:29 PM
matty's Avatar
What Flywheel are you using ? Im thinking of just switching flywheels.
There has to be a problem here. Yea granted its only there when the car is cold, but it shouldnt be doing that. Once the car is warm, there are NO Noised. Like I said, about 4 or 5 clutch releases
-matt
Old Jul 13, 2007 | 04:49 PM
Pay to Play
-matt
It's your flywheel! A friend of mine had the same issue you have, replaced his light wheel for oem..and done. There is nothing else that would cause that noise. Specially if your clutch and flywheel need to make contact first a couple times for the noice to go away. Get it???
I have a stock flywheel. Before I installed mine I did alot of research and heard that with this clutch the OEM flywheel is the best way to go
Old Jul 13, 2007 | 05:26 PM
matty's Avatar
Anyone with Clutchnet/Fidanza have this noise ??
If I switch flywheels, do I need get a new clutch or can I just switch it out ?? Im going to miss the lightend flywheel man
-matt
Old Jul 13, 2007 | 05:33 PM
mtrai760's Avatar
'Trynna' is not a word
I'm pretty sure Ian has a similiar issue, though you may want to ask him directly. He is running a fidanza/clutchnet.
Old Jul 13, 2007 | 05:37 PM
matty's Avatar
He informed me that his noise went away at 2000 miles. There is no way this noise is going away. Its been the same since I installed the setup
Old Jul 13, 2007 | 07:57 PM
Flava_24/7's Avatar
Boosted Panda
I have a clutchnet clutch and Fidanza flywheel. Ive just reached 600+miles today but I havent heard any grinding noise. I do get a moan every once in while right before it engages though.
I have to admit though I expected this stage II cluch to be a bit more stiffer then my Exedy Stage I.
Right now the pedal pressure is pretty soft compared to the Exedy. Its not mushy like its need to be bled, but it is softer then i expected it to be.
Old Jul 13, 2007 | 08:18 PM
matty's Avatar
I dont know how some people have this griding and some people dont. Its like a Quick GRIND/MOAN, and goes away after the clutch is engaged and also goes away once the clutch is warmed up...HOT !! Cause I can stop for a few minutes like to pick up food, and get back in, and itll make the noise again. Meaning it doesnt have to sit like over night to make the noise.
Old Jul 13, 2007 | 09:31 PM
Nealoc187's Avatar
SLOW
MikeD had a clutchnet and fidanza and I don't recall him ever mentioning any weird noises.
Old Jul 13, 2007 | 11:53 PM
iansw's Avatar
My clutch CHATTER went completely away at 2k miles. (I can't even make it chatter if I try now).
I get a serious moan, especially when backing up, when the clutch is cold.
But I usually only get it in the mornings, loudest in the winter months - not after just stopping/starting within a few hours.
Old Jul 14, 2007 | 08:28 PM
matty's Avatar
So I guess the Moan/Grind is normal. Im getting just a little bit of Chatter to date, barely anything though. The cold moan/grind is a bit annoying
-matt
Old Jul 22, 2007 | 10:20 AM
ObsidianIce69's Avatar
I have a clutchnet/fidanza and i occasionally get a moan, when the car is cold. Typically when backing up, but occasionally when engaging first. Either way it's exceptionally rare though and only get a moan the very first clutch release
Mar 12, 2020 12:06 AM
Maximan190
Dec 16, 2015 06:01 AM
Krazzespiinz
Sep 13, 2015 07:10 AM
hntwhttail
Sep 12, 2015 03:43 PM
Johnny9595
Sep 3, 2015 05:18 AM
