Intercooler Cooling Kit, Worth it?
Old Aug 16, 2007 | 04:01 PM
doc2278's Avatar
Doctor D I presume???
Ive been really debating this for a couple of days now. Is it really worth it to invest in an intercooler cooling kit (looks like a nitrous kit but is not). Is it worth the Hp gain? I don't know cause nobody here has got one that I have seen. I am really torn about this. Discuss......
Old Aug 16, 2007 | 04:23 PM
matty's Avatar
Happy reading !!
Great thread.
http://forums.maxima.org/showthread.php?t=531861
Short answer : Turbo and Supercharger running high boost, YES its worth it. NO HP gain, but your able to run at a safer tempurature and thats what its all about.
Old Aug 16, 2007 | 04:28 PM
Mymax97's Avatar
Hi
I think he means the spray bar (Co2). If thats what you mean then compairing to the evo my friend has with it he says he helps out so much with the heat soak in 3rd gear for him. He hasnt dynoed with it but says easily 30hp when he sprays it, just from that much of a colder air.
For you it should do wonders i dont know how recent that picture of your car is but it doesnt look like much air would hit an intercooler so this would drasticly cool down the intercooler.
Old Aug 16, 2007 | 04:44 PM
doc2278's Avatar
Thats it!!! spray bar CO2.
Old Aug 16, 2007 | 07:06 PM
Nealoc187's Avatar
SLOW
those spray bars are virtually useless. if you want something effective get a water/methanol kit. those are far from useless... they are awesome.
Old Aug 16, 2007 | 10:54 PM
Keem's Avatar
i'm looking for a intercooler for my max.... I have the V2 S-trim and only running 6 psi... and planning on running 10 psi next spring.... but want to keep my 6 psi tho.... i know sometimes u can lose psi... so wha's the best size
Keem
Old Aug 17, 2007 | 05:51 PM
doc2278's Avatar
Keem
ohh snap....a thread jack!!!!
Old Aug 17, 2007 | 06:07 PM
t6378tp's Avatar
Turbo 3.5
the water/methanol setup is alot easier and if you use alcohal it will raise the octance in your gas alittle, alot of old time street racers use it
chris you can just convert your sprayers for the window wipers
Old Aug 17, 2007 | 06:25 PM
doc2278's Avatar
any chance on Tues this week meeting up at atco and going over how to do it?
throw in a run or two?
Old Aug 18, 2007 | 04:08 AM
t6378tp's Avatar
Turbo 3.5
working late on tues, but I am going thurs and if the weather is bad friday
it's really easy I'll try to find a link or just pm you directions, if you want them before the track
pretty some-1 on here knows about it also
Old Aug 19, 2007 | 04:52 PM
doc2278's Avatar
I will get on it. Might be worth it. That way I can put the $ I would have spent on an intercooler spray kit and just do methanol injection. Put that $ towards tranny.
Old Aug 19, 2007 | 05:26 PM
t6378tp's Avatar
Turbo 3.5
don't forget nitrous is about -120 degrees ... hint hint hint hint
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
