Little black box connected to Auxiliary Fuel Pump Switch?
Old Sep 3, 2007 | 04:08 PM
BlackCat's Avatar
RIP '98 Maxima SE
Hi guys,
I was planning to take off the auxiliary fuel pump pressure switch that came with the V2 kit and noticed that the red wire from it was attached to a small black square box (circled in red). The yellow wire wasn't attached to anything as you can see and the black wire went to a ground. What's the little black box all about? It has the name Siemens on it. I didn't see any writeup in the Stillen instructions about it.
Old Sep 3, 2007 | 04:34 PM
Nealoc187's Avatar
SLOW
that is a relay......
Old Sep 3, 2007 | 04:36 PM
absoundlab
that would be called a relay
SonicDust187's Avatar
a relay......
a relay.
Old Sep 3, 2007 | 04:42 PM
BlackCat's Avatar
RIP '98 Maxima SE
Lol! Thanks guys!
I see now that the relay was listed under the Stillen Auxiliary Fuel Pump Electrical Assembly list. I guess I can just cut the connections to the relay?
Old Sep 3, 2007 | 04:44 PM
ptatohed's Avatar
Licensed to Spell
B.C.,
That's the relay. Yes it's in the write-up (well, my write-up anyway). But why is your yellow wire not connected?
Old Sep 3, 2007 | 04:55 PM
BlackCat's Avatar
RIP '98 Maxima SE
No idea! I'd better look up your notes.
Old Sep 3, 2007 | 05:15 PM
ptatohed's Avatar
Licensed to Spell
:o)
Which yellow wire are we talking about? The yellow wire on the auxiliary fuel pump pressure switch need not be used. The yellow wire on the auxiliary fuel pump relay should be connected to the OEM relay by the driver side kick panel.
You're right, the Stillen V2 instructions do not mention the installation of the auxiliary fuel pump relay (the V1 instructions do).
Old Sep 3, 2007 | 08:15 PM
Lol! Thanks guys!
Yes, since you're using the Walbro. But why cut the wires? Remove the relay and everything associated with the aux fuel pump. This will significantly cut down the wires in the engine bay.
Old Sep 3, 2007 | 08:27 PM
The V2 instructions spell it all out on page 13, and a little bit a few pages prior.
00MAXI
Sep 2, 2015 10:23 AM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
