Clutch Master Cylinders
Old Sep 8, 2007 | 02:52 PM
turbo97SE's Avatar
I recently had an issue with my clutch lines leaking and the master cylinder was starting to leak. I decided to try to upgrade to a Wilwood clutch master cylinder 3/4" thinking it would help clutch feel (Stock is 5/8"). I found that the clutch actually got heavier because the Force required is actually more on a larger cylinder - google "hydraulic force multiplication" if you want details. However, the throw of the clutch is less since it moves more fluid. I can get faster gear changes but at the expense of heavier clutch. If anyone knows of anything smaller than a 5/8" master cylinder, I could like to try it. I was thinking a 1/2" piston would feel lighter but the travel would be even more than stock! Has anyone played around with this?
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
