SFR Turbo re: 02 VQ35 Alti.
I’m sure some of you have been following this venture. Looks like they finally got it ‘done’. Or at least installed.
Not especially relative to us, but it is somewhat of a breakthrough. More so for the A34 vs A33B. But, it certainly opens the door for the A33B as well.
http://www.nissanclub.com/forums/eng...-complete.html
me =
.Must have been the Altima mood in the air.
That is really great news, they did mention the maximas in their thread. So that brings some hope of seeing a FI kit for the 5.5.
Also I believe SFR did this a while back for someone that used to post here, he had a silver Altima with a bodykit, and had a marines banner on the windshield.
http://www.my350z.com/forum/showthread.php?t=302619
Originally Posted by TurboTim
Our 3.5L 2002 Altima test car is finally finished.This car is an automatic with the Speed Force Racing turbo system.We Got on the dyno today to tune it and the results were great! The stage 1 set-up which runs a little lower boost level made 300WHP at 5 psi. The stage 2 system made 374WHP at 8 psi! This is out of an automatic too.The manual cars will make more power then this. We managed to shoot some video footage of the dyno runs,driving in the car and also some footage of the car driving by. We still need a five speed and six speed Altima as well as an Automatic,five speed and six speed Maxima.
This is a cool little project we just completed that I thought some of you would get a kick out of. A 3.5L single turbo automatic FWD Altima with 374WHP on a stock motor @ 8 psi of boost Now this is how you go and get groceries! Enjoy. Oh and watch out you guys with superchargers and low boost turbos systems cause you might be getting whooped by some front wheel drive Altimas and Maximas very soon
Need to see how/what he's doing/using for FM. I asked the question on the 1st or 2nd page, but I don't think he's answered me just yet.
Jut getting the normal,' ZOMG!!! Nice work!!/Will it fit my *insert tranny/year type here* car?!!11' type of replies/posts in there for the most part.
Some ask the same thing in my350 but this was his response:
Secondary butterfly in the intake manifold and no smoothing of the graph.And the correction factor was 1.05
Of course I'm sure they can be corrected, but I wonder if he knows that.
Like I was telling NmexMAX, I think its the ecu taking back timing. Most 3.0, 3.5's peak tq is at around 4500ish more or less which is close to where this dyno curve drops. So i really think that the setup is causing alot of knocking, its not even intercooled!!
Wait, I see a intercooler in the photos and the video. You think they would be running the car like that if it was knocking???
look at the dyno and pictures, you do not see an intercooler the filter is in the engine bay directly on the shiny turbo. They probably dont even notice the pinging over the exhaust.
More info from TurboTim:
"If the guy that has been posting about this on the Maxima.org could copy and paste this over there,that would be great.First off,I cant post on the Maxima board, it says I am trying to edit someons post or I dont have access! What the heck is that about?
Onto the questions.The dip in the curve is what we beleive is the secondary butterfly opening.Both dyno charts have a wierd curve to them and we seen this on the last Altima and Maxima we turboed a few years ago.This turbo is smaller then the full T-4 we used on those earlier turboed cars and the peak torque is coming in really late on both of these newest charts. There was no detonation(knocking)and the air fuel mixtures were good.Right where we want them.The timing was conservative and we pulled a few degrees on the higher boost run.There was nothing out of the ordinary.We will be doing a system for the Maximas so stay tuned for that."
Did you look that up before you typed that?
Limited Spec (L-SPEC) Flash
Features
- 7100 Rev Limiter (500rpm Increase)
- Speed Limiter Removal
- Drive By Wire Re-mapping
- Stock Fuel, Timing and CVTCS map (no changes)
http://www.technosquareinc.com/limited.htm
Features
eng92 has some data listed here: http://forums.maxima.org/showpost.ph...6&postcount=47
That and I have access to a local stock softwared A33B. I conducted my own tests. I also had Elon Hayes send me some TPS data and compared them as well.
Our true TPS data doesn't differ no matter the situation
Interesting,
Here's my experience:
If I floor it from a stop it shifts aggressively from 1-2 and from 2-3. But "something" happens in 3rd gear. It almost feels like I'm letting off the gas. After maybe 1.5 seconds the power comes back on again. You can actually hear the power drop and then come back on. Could it be the auto tranny "flash speed"? I always attributed it to the DBW.
Now if I'm just cruising in 3rd gear and floor it the power is instant. Weird.
It's the lock-up torque converter doing its job.
http://forums.maxima.org/showpost.ph...6&postcount=16
The links are dead.
Can you explain?
Can you explain?It's the lock-up torque converter doing its job.
If you leave it in D or shift to 4th, it wont happen.
My 4th gen did, my 5th gen does it, and I've seen 6th gen dynos that prove it. It's unlocking at that point. Disengaging since you're going into say a high load mode so it unlocks. Locking TC helpes MPG, when it's locked, if you're @ 3k in 3rd, and the shifter is in 3rd (vs D) you're not looking to save MPG.
Oh, wow
That's crazy. I wish it wouldn't do that. I've been in a couple of "runs" where it seemed like an eternity before the power came back.
