Quick ? on Split T3 Turbines
Old Dec 11, 2007 | 04:12 PM
95BLKMAX's Avatar
AKA Twin Scroll????
Those turbine housings with the split in the middle of the hole.
While shopping around at a local speed shop, I overheard the sales guy tell this cat who had a turbo with a split T3 turbine, sales man mentioned to the guy that he should reconcider that housing. Basically the point that he was trying to make was that a twin-scroll turbine husing is meant to run on a manifold designed to flow equal amounts into both holes. That it would still work, but it would not be optimal flow to have, say a custom feedpipe into a T3 flange and have that split there. That the split would create alot of turbulance and might cause ~20whp.
The theory behind what he was trying to say makes sense to me, but I know there's got to be a few here with a turbine with that split at the inlet.
What do you do with it (if anything at all)?
Is there some sort of flange that will have an edge on the split side to "cut" the air before going into the turbine?
Do you go downtown with a grinder and smooth it out at the turbine housing itself?
Any input strongly appreciated
Old Dec 11, 2007 | 04:34 PM
kzoosho's Avatar
if it was a feed pipe you could just get a new flange but if it was a manifold i would say grind.
Old Dec 11, 2007 | 04:49 PM
95BLKMAX's Avatar
Oh see what Im trying to say is that the turbine housing ITSELF has that split on it. The dude went to the store to buy a flange. This is why the salesman mentioned the deal with re-concidering the turbine housing.
In this fashion...
Old Dec 11, 2007 | 05:30 PM
kzoosho's Avatar
Wow you got me here lol
Old Dec 11, 2007 | 05:34 PM
95BLKMAX's Avatar
lol, now you see the worry I have in my head? (woops, I mean, the head of the guy that walked into the store with the turbo while I was there ).
Maybe 95turbogxe will shime in, since this is the type of turbine housing found on HX35s
Old Dec 11, 2007 | 08:56 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
i would grind it down the guy at the speed shop was correct just for splitting the gasses into the turbine evenly, good for twin manifild or a Inline 4-2 manifold
, straight 4-1 = hp loss but not much,
just grind it down. i think that you can buy the flange on ebay but would be pretty pennies like 20+ dlls
22.00 shipped
http://cgi.ebay.com/ebaymotors/T4-T-...spagenameZWDVW
Old Dec 11, 2007 | 10:00 PM
Nealoc187's Avatar
SLOW
bah, i wouldn't worry about it. in fact i didn't worry about it and i will continue to not worry about it. i think that 20hp estimate is gross overkill. even if by some chance it did have that large of an effect, which it won't, what's 20hp? add another pound of boost and make your 20hp back. most turbos being used out there have more than enough capability to break your trans every time you floor it if you really want to, so complaining about a 20hp loss on a maxima is pointless. you aren't going to be maxing the turbo out anyways. some of the fastest maximas on this board are using split housings without doing anything special to compensate.
Old Dec 11, 2007 | 10:29 PM
95BLKMAX's Avatar
, thats the same thing I was thinking. Its not as if Im maxing out the turbo to the point where that split may make SUCH a difference as what he was saying.
However, I do want to help to make that as smooth of a split into the turbine as possible. Im going to grind the split ON THE FLANGE [not the turbine, in case in the future I want to upgrade and sell this device] into a rounder or if possible sharp-edge face to more easily "slice" the stream of air going into it. Its not as if its going to harm anything, so really I have nothing to loose on doing this, and MAYBE something to gain.
I guess I'll be doing it just for my own peace of mind.
Old Dec 11, 2007 | 10:36 PM
95BLKMAX's Avatar
Holset HX35 is one HEAVY ****! Package said 30lbs, and I dont think that was exaggerated, LOL. Diesel powah FTMFW!!!!!
Old Dec 11, 2007 | 10:38 PM
wunfstmax's Avatar
Pretty much what neal said. The twin scroll turbine housings can definately be of use on a smaller motor trying to spool a large turbo(ie 1.8 honda spooling a gt42r). I run a divided housing with a undivided flange and it works just fine.
Old Dec 14, 2007 | 08:12 AM
95turbo gxe's Avatar
I ran un divided flages with the hw35 with no problems but now Iv bought a divided flange and going to the divided it all the way to the turbo for the pulse set up! Sr20 pulse set ups make over 50 more horsepower and come on about 500-1000rpms sooner with the same turbo and boost setting
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
sliptap
Sep 30, 2015 05:57 AM
Serotta33
Sep 17, 2015 12:14 PM
