Show me those FRONT MOUNTS!!
Post pics of your FMIC setup. Please post pics of piping and the way its ran also, please post also the fmic dimentions and piping size used. I am looking to add a FMIC to my SC setup and I want to get an idea of what is involved with this.
holy thread jack batman.
the CA isn't bad. its only running stock boost which is 6-7 psi. I've only been able to drive the car around my neighborhood since it is in desperate need of a back window. I'll probably just end up putting on a whole new Convertible top instead of just doing the window.
I dont remember the exact dimensions, but I do believe that it is a 28x12x3 intercooler with all 3 inch piping on a vortech v2 blower, hope that this helps you out a little bit
running the piping down through the front to the intercooler instead of going through the fender, the blower is clocked downwards to eliminate a bend and the pipe that you see running into the fender is the CAI for the supercharger
if you look closely you can see the top of the Tial 50mm BOV mounted behind the drivers headlight inside the fender
the intercooler all bolted up into place with all the pipes ran
final shot of everything with the front bumper re-installed on the car
