my attempt at a build thread
Old Jul 5, 2008 | 10:08 PM
maxmaxima91's Avatar
So i decided to rebuild my setup. Old setup has over 50k miles on it and since it was only made of regular steel to begin with, its has become a bit tired. There were a few cracks that were starting to bother me. Since i built my last setup my fabricating capabilities have changes so.. i figured i would finally apply it to my own car. With this new build i wanted to experiment with something that has been on my mind for quite some while. A "Quick Spool Valve". Basically ..My turbo is huge, and i Love the top end. Yet, i know i could really benefit from better spool. So rather than sacrifice the great top i decided to try this. To sum it all up, the valve when you first hit the gas, it will divert all the exhaust through one scroll of the turbo. This essentially changes the turbo from being a 1.32 a/r into a .66 a/r. Hopefully this mean i will get full boost sooner than 4000-4500 rpms. so.. on with the pictures.
Valve.
closed
open
headers and y pipe
Old Jul 5, 2008 | 10:09 PM
Old Jul 5, 2008 | 10:10 PM
50mm wastegate
Old Jul 5, 2008 | 10:11 PM
Collectors
new exhaust parts
Got maximas?
yup.. i hope the pics explain it so far. much more to come.
Old Jul 5, 2008 | 10:22 PM
kzoosho's Avatar
Looking good man.
Old Jul 6, 2008 | 07:37 AM
Bernardd's Avatar
Very nice, can't wait to see the results.
Old Jul 6, 2008 | 08:13 AM
WhiteA32's Avatar
WOW, awesome work man
Old Jul 6, 2008 | 09:20 AM
MDeezy's Avatar
Very clever!!
How do you plan to control the valve?
This gives you the best of both worlds, a smaller a/r for spool up, but then opens up for better top end.
in for more results/pics
Old Jul 6, 2008 | 10:04 AM
nismology's Avatar
Bad a$$! It's not too often I'm truly impressed by maxima turbo setups.
Old Jul 6, 2008 | 10:05 AM
The valve will be controlled electronically using a starter style solenoid to actuate it. the solenoid will be controlled using a circuit that my electrical engineer friend is building for me. Basically using the same map sensor voltage that my engine management datalogs, at chosen points in that voltage scale it will turn on the solenoid and then at a higher voltage turn the valve off again. The kick in and kick out points will all be adjustable. This will mean while cruising the valve will be open allowing the engine to breath as well as possible in order to maximize mileage, then once i punch the throttle and manifold pressure reaches say 3 inchs vacuum, the valve will slam shut. This in order to help spool. From there once the boost reaches say 10psi, the valve will be ordered open again. The turbo is ideally spooled at this point and the engine will have no problem reaching the ultimate desired boost levels of some where in the high teens and eventually twenty's.
Old Jul 6, 2008 | 02:27 PM
Nealoc187's Avatar
SLOW
It's about time...
Old Jul 6, 2008 | 02:53 PM
choray911's Avatar
The Crazy Azz Cracka
Nice work!
Old Jul 6, 2008 | 08:18 PM
redsohcturbo's Avatar
man, finally....a build thread from my little brother.
the pics dont do it justice, the fab. work is very impressive. the old setup turned heads for 3 years, and the new one should do that much better, while making the car an 11 second car finally
Old Jul 6, 2008 | 10:36 PM
NiZMo1o1's Avatar
Sexay !
Old Jul 6, 2008 | 11:01 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
pretty *****in, where did you get your exaust pipes from?...
Old Jul 7, 2008 | 09:28 AM
liqidvenom's Avatar
brotherhood of tq
very nice setup you having going.
Ive seen that valve setup on a camaro and it seemed to work pretty well. I htink his was done with a switch in the car he controlled or something if i recall
Old Jul 9, 2008 | 10:36 PM
update...
Turbo with V-band welded on
all welded up...
Old Jul 9, 2008 | 10:37 PM
Did some frame reinforcing under the radiator. plated it with 1/4 steel, and angled up to the main frame rails on each side.
Some wheel well rust repair.
Old Jul 9, 2008 | 10:38 PM
Oil take off for the new oil cooler/filter relocation setup im installing.
finished fabing my new front engine mount. still have the back to go. i feel it turned out well. All poly bushing.
after por15
Old Jul 9, 2008 | 10:40 PM
Old Jul 11, 2008 | 04:36 AM
the mounts look amazing in person...the rear mount is beautiful.
this is going to be a mean setup. this car rules a lot more now than when i drove it to high school 8 years ago!
Old Jul 11, 2008 | 06:54 PM
maxgtr2000's Avatar
KH3 by popular demand
You have a car lift in your garage and you know how to weld.
Maaaan the possibilities. That thing looks like it will be a beast.
Old Jul 11, 2008 | 11:17 PM
Cross member with integrated oil lines
Old Jul 11, 2008 | 11:26 PM
and I got the headers and Y pipe back from the ceramic coaters today
Old Jul 11, 2008 | 11:32 PM
Old Jul 12, 2008 | 05:31 AM
MINT
Old Jul 12, 2008 | 09:16 AM
one_fast_max's Avatar
dang bro!! very freakin impressive! i've been wondering what you've been up too!! haha. looks great man!
i'm along with neal on this one....." its about time" haha
Old Jul 12, 2008 | 12:38 PM
jonmandude's Avatar
Wow, very nice work. What numbers are you aiming for now?
Old Jul 12, 2008 | 03:07 PM
Pearl93VE's Avatar
I can has?
My god, this is an amazing setup. There better be video's, video's, video's when you're done. Way to represent the third gen.
Old Jul 12, 2008 | 03:13 PM
NiZMo1o1's Avatar
dayum thats sexay as fawk... BTW PMed ya
Old Jul 13, 2008 | 11:35 AM
jdmjunky's Avatar
wow! U should look into makin and sellin turbo kits especially for the 3rd gen! I would be one of the first ones to get one!
Old Jul 13, 2008 | 11:46 AM
xx-Marshall-xx's Avatar
kthxbye2u
I yelled out "Oh my gawd!" when i scrolled down to see the finished pipes
that is just amazing. Beautiful!
Old Jul 13, 2008 | 06:47 PM
mooseq30's Avatar
I just love the ideas behind this build, its definitely been discussed between me and some guys I know before, 'the efficient turbo setup' is what we'd call it, big turbo with no lag due to twin-scroll with one side spooling right away by building quick pressure and heat, than utilizing the flow of both sides for the lots of power capabilities, its like a twin turbo setup but with half the pipes and weight! Just love it! Can't wait to see a dyno! Bet you'd make twice as much torque as before, better get some good rubber if u don't already have some. lol
Old Jul 13, 2008 | 07:03 PM
burhan92SE's Avatar
dyam.......we proud of u
Old Jul 13, 2008 | 07:32 PM
505max94se's Avatar
Impressive work!
Old Jul 14, 2008 | 08:30 AM
DandyMax's Avatar
3.5 in the works
Impressive, you've got some real fabrication skill there!
Did you do any math/engine modeling to size the piping dia's/lengths?
Old Jul 14, 2008 | 05:11 PM
Matt93SE's Avatar
STFU n00b!
Looks nice, but I'd like to offer some of my experience from breaking stuff... you'll need to reinforce your crossmember more than you have. I don't know if you put any plate across the bottom too, but you need to run a section of plate down the sides of the xmember near that engine mount. you should also weld some small gussets onto the leading and trailing edge where it sticks up so that you don't tear that mount off the crossmember when all that heat-hardened metal around the welds starts cracking.
(Don't ask how I know.)
..... And when are you going to start building equal length headers for us NA guys? I'd do it myself, but don't have the time...
Old Jul 14, 2008 | 05:31 PM
well.. i reinforced the cross member when i first turboed the car and it was fine up to almost 400 ft/lbs. That includes 6500 rpm clutch drops on 26 inch slicks.. and hours on the road coarse. With the modifications i have made it even stronger. since the pictures i added even more steel to the front and gusseted the rear mount, and yes the bottom has a steel plate running all the way down it.
Thanks everyone to the positive feedback. This build is killing me and my wallet.
